TheTourist
- 22
The current I=I0exp(-t) is flowing into a capacitor with circular parallel plates of radius a. The electric field is uniform in space and parallel to the plates.
i) Calculate the displacement current ID through a circular loop with radius r>a from the axis of the system
ii) Calculate an expression for the electric field between the capacitor plates.
i) As the plates are being charged up by the current I, the displacement current ID is increasing due to a growing electric field between the plates. I therefore reasoned that as the current I is decreasing with time, the displacement current is increasing with time by an equal amount so the answer would be ID=I0exp(t).
Though I don't know if this is correct.
ii) I used Gauss's law in integral form and a cylinder around the positive capacitor plate.
\intE.dS=Q(t)/ε0
I performed the integration using the top surface of a cylinder, RdRd\phi\hat{z}
and ended with the equation E(t)=Q(t)/(ε0πa2)\hat{z}
where a=R and I=dQ/dt
