Studiot pointed out that PV
n = constant is a polytropic process. It would help to point out that a polytropic process (almost?) always refers to a process that a gas undergoes.
Wikipedia suggests that one could apply it to a liquid or a solid but I think that's very uncommon.
A polytropic process for a gas is one in which a gas is compressed or expanded, heated or cooled.
RoyMech.co.uk has a decent article on it.
An adiabatic process is simply one that has no heat entering or leaving the gas, so the only energy going into or coming out of the gas is work. If there's no heat transfer into or out of the gas, and work is being done on or by the gas, it is also an isentropic process. For an adiabatic process, the polytropic exponent, n, becomes the ratio of specific heats for the gas. So the equation would become:
PV
k = constant
Note that k is the ratio of specific heats, C
p/C
v and also sometimes called "γ". This is a special case of the polytropic process since the exponent n, can be any value.
Some of the other values for n were pointed out by Studiot and can be found on the Wikipedia article. Another one that's of interest is when n = 1. In that case, the temperature of the process does not change. It is an isothermal process. So if the gas is being compressed or expanded and the gas remains at a constant temperature, heat has to be removed (during compression) or added (during expansion) to keep the temperature constant.
A polytropic process and the general equation that describes it (PV
n = C) is just a general equation that can be used to describe a wide variety of different processes depending on whether the gas is compressed or expanded, heated or cooled.
