Measuring resistance using potentiometer
32 replies · 10K views · last reply
Faris Shajahan said:
I don't think that would solve the problem. Because even then, the current in both would be different.
That is what we want. Now the potential difference across the resistors will be different.
Usually this experiment is done with the resistors connected in series to the cell, in which case the
current will be the same through both resistors.
For this particular setup I can only reduce it to two unknowns, the resistance X, and the internal resistance of the cell.
Handwritten notes on paper: V = kl, V_R = kl_R, V_x = kl_x, i = V/R, and e = i_R(R+r) = i_x(X+r), with a circuit sketch of a resistor R in series with a cell e of internal resistance r.
Handwritten algebra on lined paper deriving l_R/R(R+r) = l_x/x(x+r) with unknowns x and r, expanded and rearranged to (l_R/R - l_x/x)r = 10.2 cm.
Yes, it will be different but still it would be impossible for us to calculate the value of ##X## as we don't have the value of ##r## given in the question.
Instead if they say there is a rheostat in series with ε in order to maintain constant current in both the cases, then we can calculate ##X## as
##X=R\frac{l_2}{l_1}##
