How Can You Measure the Force of a Punch?
  • Thread starter Thread starter Jesstilla
    Force Measuring
To measure the force of a punch, a spring scale can be used, oriented horizontally and recorded with a video camera for analysis. However, measuring the average force is more appropriate, as the force exerted during a punch varies significantly. A digital force meter capable of rapid measurements is recommended for capturing the dynamic nature of a punch. Calculating impulse, which considers both average force and contact time, provides a better understanding of a punch's impact. Overall, the setup requires careful calibration and consideration of the varying forces involved.
Jesstilla
Hello,
I am trying to help a student set up an experiment in which he needs to measure the force of a punch. Any suggestions on what equipment/sensor I can use to do this?
Thanks!
Jessie
Jesstilla said:
Hello,
Thanks!
Jessie
Welcome to the PF.
One option that comes to mind is a simple spring scale (like you weigh food on) and a video camera. Orient the scale horizontally, and record the dial with the video camera. Then step back through the video frame-by-frame, and plot the readings.
You would need to look around some to find the spring scale that is most suited to punching (short/stiff travel spring, light dial for quick readout, etc.). Or you could make one, as part of the overall project! Make a platform with spring(s), and use some sort of marking scheme to show the displacement. Then use the spring equations to calibrate the whole setup...
this is a complicated problem. first of all, asking 'what is the force?' does not really make sense. the force exerted during a punch will vary greatly. a more appropriate question might be what is the average force exerted during a punch, but even this is probably not what you want because the 'real' effect of the punch will depend on the time of contact. I think a better measure of what a person might think of as the effect of the punch would be the impulse. this is the average force multiplied by the time of contact.
the only way i can think to do this is with a digital force meter that can take many force measurements in a very short time. then you can do a numerical integration to find the impulse.
spring scales and the like are good for measuring constant forces, but will not be very effective for a quickly varying force like that of a punch.
good luck
  • · Replies 62 ·
  • · Replies 33 ·
  • · Replies 35 ·
