Mechanical efficiency of IC engine
The mechanical efficiency of an internal combustion engine is calculated using the formula n = (Pb / Pig) = 1 - (Pf / Pig), where Pb is brake power, Pig is gross indicated power, and Pf is friction power. The discussion also touches on the formulas for indicated power (ip) for both 4-stroke and 2-stroke engines, though specific formulas for ip were not provided. Clarification was sought regarding the term "ip," with a suggestion that it might refer to indicated pressure. Understanding these formulas is crucial for evaluating engine performance and efficiency. The conversation highlights the importance of precise terminology in discussing engine mechanics.
aruneswaran
what is the equation for the mechanical efficiency of an internal combustion engine?
what are the formulas for 'ip' for 4-stroke and 2-stroke engines?
thank you
Mechanical efficiency n:
n = (Pb / Pig) = 1-(Pf / Pig)
Where Pb is the brake power, Pig is gross indicated power, and Pf the friction power.
What do you mean by ip? Indicated pressure?
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 35 ·
  • · Replies 58 ·
  • · Replies 123 ·
30K
