Mechanical Energy - Two Questions
To determine the height the Olympic runner's center of mass is raised during the jump, use the formula for gravitational potential energy, which relates initial vertical speed to height. For the pendulum bob, the initial height can be found using the principle of conservation of energy, equating kinetic energy at the bottom of the swing to potential energy at the initial height. The hint suggests focusing on the relationship between speed and height for both scenarios. Understanding these concepts will help in solving the problems independently. The discussion emphasizes applying energy principles to mechanical energy questions.
JeremyM
The questions read...
1.) An Olympic runner leaps over a hurdle. If the runner's initial vertical speed is 2.2 m/s, how much will the runner's center of mass be raised during the jump?
2.) A pendulum bob is released from some initial height such that the speed of the bob at the bottom of the swing is 1.9 m/s. What is the initial height of the bob?
What are the formulas I would use? I only want the formulas for now because I would like to try and solve it myself. Thanks!
Well, I won't give you the formulas, but I'll give you a hint or two.
On the first one, the problem is the same as if you asked "what height would an object reach if it's initial speed were 2.2 m/s vertically upward?". The fact that they're asking about the runner's COM makes no difference.
For number 2, think about it from energy considerations - at the bottom of its arc, the pendulum bob has a certain amount of kinetic energy. Where did that energy come from?
10K
  • · Replies 29 ·
  • · Replies 19 ·
