Mechanics of Rolling and Striking Cones
  • Context: Undergrad
  • Thread starter Thread starter EngineeringFuture
    Cone Rolling
The discussion explores the mechanics of rolling conical objects, specifically whether they can roll in a straight line under various conditions. Participants examine the effects of shape, friction, and forces applied to the cone, considering both theoretical and practical implications.
  • One participant questions if a conical object can roll in a straight line, suggesting that it may require specific forces applied at different points.
  • Another participant argues that if the circumference of the roller varies, such as with a cone, friction will prevent free rolling motion in a straight line on a flat surface.
  • A practical example is provided where a conical roller made from paper demonstrates slipping when rolled, indicating challenges in achieving straight-line motion.
  • Concerns are raised about the implications of different parts of the cone traveling different distances when rolled, suggesting that this would not result in straight-line motion unless slipping occurs.
  • Some participants express uncertainty about the conditions under which a cone could roll straight, with one acknowledging a misunderstanding in their earlier statement.
Participants express differing views on the ability of conical objects to roll in a straight line, with some asserting that it is possible under certain conditions while others argue that friction and varying circumferences complicate this motion. The discussion remains unresolved with multiple competing perspectives.
Participants reference the need for diagrams and mathematical explanations to clarify their points, indicating that the discussion may benefit from visual aids and further exploration of the mechanics involved.
EngineeringFuture
TL;DR
Mechanics of rolling cones
Does an object have to be either spherical or cylindrical to be rolled in a straight line. Could an approximately conical object be rolled in a straight line or struck to roll in a straight line? A cone can be rolled in a straight line if different forces are applied at different spots, but once the force is no longer applied, can a cone keep rolling by its inertia alone?
I believe the answer is no, not if the apex of the cone remains on the surface, but I think there are unusual surfaces where a cone of non-uniform density where a cone would slightly deform so the apex would lift into the air and the cone would keep rolling.
Also, my terminology is terrible, so please excuse my terminology. There is one concept that I'm thinking about but can't express.
If the circumference of the roller varies, like a cone or frustum, and remains in frictional contact with the flat surface, then the friction will prevent free rolling motion in a straight line, on a flat surface.
Do you have any links I could see with the diagrams and math worked out?
This is more fundamental than mathematics.
Make a conical roller from a sheet of paper and some sticky tape, like a witches hat. Roll it in a straight line and watch how it slips.
If wheels of different circumference, rotate at the same rate, they will travel different distances along arcs of different radii.
When you drive a car around a corner, the wheels on either side rotate at different rates. That is why there is a differential gear.
Conical rollers are used in tapered roller bearings, where the path lengths are in proportion to the roller circumference.
Could an approximately conical object be rolled in a straight line...
Sure, even uphill.
TL;DR Summary: Mechanics of rolling cones
If the cone is a solid material and the contact with the floor doesn't slip then that is not true.
Why? If the cone rotates once then the distance travelled (on a plane surface) by the part with least radius (r1) will be 2πr1 (the circumference) and the distance travelled by a part near the maximum radius (r2) will travel 2πr2. That implies the fat end travels further than the thin end. That isn't in a straight line. To force a straight line you have to let every part slip.
You're absolutely correct. I was an idiot above.
  • · Replies 116 ·
13K
12K
9K
  • · Replies 35 ·
