Mechanics Question of a particle
The discussion revolves around resolving forces acting on a particle, specifically forces P and Q, with P having a magnitude of 7N due north and the resultant force being 10N at a bearing of 120 degrees. Participants suggest using the cosine rule and resolving the forces into components to find the magnitude and direction of Q. After some back-and-forth, it is clarified that the angle used in calculations should be correctly identified, leading to a better understanding of the vector relationships. Ultimately, the problem is solved, and the participants confirm the accuracy of the calculations and the approach taken. The thread concludes with a note to mark it as solved.
_Mayday_
[SOLVED] Mechanics Question
Hey.
I have a quick question relating to what I think is resolving forces. I am stuck at the first hurdle, I have no idea how to approach it.
Question
The forces P and Q act on a particle. The force P has a magnitude of 7N and acts due north. The resultant of P and Q is a force of magnitude 10N acting in a direction with bearing 120. Find:
(a) the magnitude of Q
(b) the direction of Q, giving your answer as a bearing.
Attempt
No idea, but as there isn't going to be a right angle in this case, I would assume this question would involve the cosine rule? Could someone please give me a nudge in the right direction.
Thanks
_Mayday_
Resolve the resultant into its components (i and j).
Okay, I have given it a bash. I don't know if someone has responded as I haven't refreshed the page.
Using the cosine rule.
a^2=b^2+c^2-2bc\cosA
a^2=7^2+10^2-2(70)\cos30
a=2.79NNow for the second bit I just calculated the angle using trig and got 105.57 degrees. Now I simply subtract that from 360 which gives me 284 degrees.
Hope this is somewhat along the right lines!
_Mayday_
Probably a silly question, but in Trig, what happens if your opposite side is also the hypotenuse? What do you do?
Hey Nokia, is my answer correct?
a=2.79N
_Mayday_
Hey _Mayday_,
Not sure what you're doing here, but you're certainly not following nokia's hints. Nokia suggested that you resolve the to two forces into perpendicular components. So for example,
\mathbold{P} = 0\mathbold{\hat{i}} + 7\mathbold{\hat{j}}
Can you do something similar for Q?
I'm assuming that you mean in the case of a right-triangle, in which case your angle in \pi/2.
For P (0i + 7j)
For R (8.6i - 5j)
Ahhh, I've just figured out what your doing! However, the angle
a=2.79N
Should be 120o not 30 o. The angle that you take should be opposite the side you are trying to determine.
I actually think it should be 60. 7N acts vertically upwards. The resultant acts at 180 - 60, so when I add that vector onto the one of 7N you get 60.
Correct me if I am wrong though! I just drew it out and it looks good to go!
A bearing of 120 degree means, 120 degrees clockwise from North. So start by drawing a vertical line upwards, this is P. Now from the point where you started to draw P, draw a second line at 120o clockwise measured from your vertical line, this is the resultant vector. Now draw a third line joining the ends of the previous two vectors, this is Q.
If I put arrow heads on the forces, do they not need to follow on? The way you have said it means that the arrow heads will not follow on.
If the cosine rule works well, then I would prefer to do it this way.
Yes the do follow on. P starts at the origin, Q starts from the tip of P and points in a generally SW direction. The resultant force then starts at the origin and points towards the tip of Q. Could you perhaps post your diagram?
Here we go.
Is that correct?
_Mayday_ said:
Is that correct?
Does it look right to you? If you have two forces acting on a particle, one acting left and one acting upwards; how can the resultant force be acting downwards and rightwards?
Bah, dammit I've got it now! Cheers Hoot.
A pleasure as always _Mayday_ :smile:
Don't forget to mark the thread as 'solved' when you're done.
!(Solved)!
  • · Replies 18 ·
  • · Replies 42 ·
