Melt Ice Quickly: Best Ways to Do It
  • Thread starter Thread starter HK911
    Ice
The discussion centers around methods to melt ice quickly within a two-minute timeframe, specifically in an indoor environment at room temperature. Participants explore various techniques that rely solely on conduction and convection, avoiding the use of chemicals or external heating sources.
  • Experimental/applied
  • Some participants suggest maximizing heat transfer by breaking the ice into smaller pieces to increase surface area.
  • There is a discussion about the effects of pressure on the melting point of ice, with some arguing that increasing pressure can lead to melting, while others question its effectiveness.
  • One participant proposes using a heavy object to apply pressure on the ice while rotating the container to generate frictional heat.
  • Another idea involves using a vertical tube to create a cold draft that draws warmer air down across the ice.
  • Some participants mention the potential of using a thawing plate made of metal to facilitate heat transfer.
  • There are suggestions about draining melted water to prevent it from absorbing heat and hindering the melting process.
  • Concerns are raised about the limitations of using room light for heating and the requirement to crush the ice during the experiment.
Participants express differing views on the role of pressure in melting ice, with no consensus on whether increasing or decreasing pressure is more effective. The discussion remains unresolved regarding the best method to achieve the goal within the constraints provided.
Participants note limitations such as the inability to use external heating sources or chemicals, and the requirement that ice must be crushed during the experiment rather than beforehand.
This discussion may be of interest to individuals involved in experimental physics, engineering projects related to thermal dynamics, or anyone exploring practical applications of heat transfer principles.
  • #31
Gravity considered passive, eh? Because if you held the ice in callipers as it melted it would pitch to the floor, no one is dropping it, the higher up you put it the better, it would melt in no time then. :) as it would be spread over a massive surface area. Sadly I think that counts as dropped though. If you used a catalyst that increased ice melting without chemical reactions that might be passive?
  • #32
Gravity is passive. But how high would you have to place the ice cube to actually have some sort of effect. The experiment would be carried out on a table. Here is some more information.
Project Statement:
The project team is to design, analyze, build and test a "passive" heat transfer device to enhance the defrost process as realized by the melting of ice. Passive means no energy input is to be utilized during the operation of the device. To remain in context with the above described devices, the ice may not be modified in any manner. The device must also begin at room temperature. A device must be manufactured by the project team. At the end of the semester a competition will be held during which the device will be judged on the basis of the ice melting rate produced, the mass of the device, and its cost. The device must fit inside a box of dimension 14" x 14" x 12"
  • #33
HK911 said:
Above is a few of the frequently asked questions. If we used the plates, would it be best to place it in some sort of container? We were thinking of designing a box made from acrylic with holes in the bottom and top to all air to flow. Should be do that are just let it sit in the air with no casing around it?
Open to the air would work best, I should think. I did not realize it was such a small block of ice. The inside of a metal ice cube tray would not work very well on this particular body of ice, you would only and a cutting it into two or three pieces. You will want your plates to be much closer together than this. Also, you should try to get them to line up with each other (if you use the "sandwich method" of placing one grate beneath the block and one above it).
  • #34
Adding pressure will indeed melt more ice for reasons explained by "billiards". A quick test is that you can press your thumb into a block of ice and create a small dimple in the ice surface.
Anyhow, I would consider making a device where ice is placed inside a spring loaded "vice". At the start, the spring would be compressed most and will exert the maximum force on the ice.
As the ice melts, the spring would cause the vice jaws to move closer but still maintain contact with the ice.
Also, I would allow the water produced to run off. Keeping the ice in water-bath will set up an equilibrium between the ice-water system and some of the water molecules may become ice again. Also, one would expend part of the energy to evaporate water.
You may also think about rigidly attaching some sort of fins for accelerating the heat transfer. Make sure that the fins are integral (read: welded) to the vice jaws. Or else, the fins would be useless if there is an air gap between them and the jaws.
I am sure you can come up with multiple designs. This is just one possible solution. However, if you want to put some mathematics to all of this, it is beyond me. Look into FEA if you want to decide between a couple of designs.
Good luck!
Another option is to concentrate the force on a small area to create more surfaces really rapidly.
  • #35
Schrödinger's Dog said:
Yeah I know that but it doesn't prove that reducing and heating would be better than increasing pressure at all.
Uh, ok, you're right, but I don't remember claiming to prove anything, or even hinting that "reducing and heating would (not) be better than increasing pressure" ... whatever :rolleyes:.
Bodies of water would also freeze from the bottom up making life difficult to get started in the first place.
No they wouldn't, even if the ice formed in the deep it would float up to the surface by buoyancy. You can't be still be claiming that the melting temp of ice is higher at higher pressures, I would agree if we were talking about ice III, V, or VII, but we're talking about everyday "normal" ice here: ice I, which if you look at the http://www.homepages.ucl.ac.uk/~ucfbanf/water_ice.htm" for water ice you will see has a negative Clapeyron slope. As I mentioned earlier this is important for life, because it means that under great ice bodies, where the pressure is high, the ice can melt more easily providing underwater reservoirs which may harbour life (chemoautotrophic life, probably) - c.f. Europa. It's also an important mechanism for the movement of glaciers, the water at the bottom of a glacier pushes the ice upwards reducing friction with the ground accomodating "basal sliding".
  • #36
HK911 said:
Q: Can solvents be added to the ice?
A: No, nothing can be added to change the chemical composition of the ice or that creates an endothermic or exothermic reaction. Clarification: in any part of the device, no substance that creates an endothermic or exothermic reaction is considered to be passive as it is stored chemical energy. Solvents include but are not limited to fertilizer, cat litter, sand, bleach, sugar.
Q: Can we use additional water?
A: As long as it does not come in contact with the ice, ice/water mix. However, if you’d like, you may use the water from the melt.
Hmm... If you can only use additional water if it doesn't come in contact with the ice, can you use other chemicals if they don't come in contact with the ice?
  • #37
12x12x14 isn't a very big box, and a foot of gravatic drop will add very little energy to a block of ice. Even one the size of a large Tim Horton's coffee. So...Hmmm...
Chemicals...out
Gravity... in, but not usefull
Smashing...in, but not usefull (will the ice break in a 9" drop? I think not.)
Melt water..in
New water..in, so long as it does not mix with melt.
Lenses...in.
Question: If I put the ice in a beaker, and I put the beaker in a box, can I pour boiling water into the box to heat the beaker, and by conduction the ice? Unknown, but bet no. Please clarify OP, 'cause that would be the best bet hands down.
Otherwise...
A Box Oven! Used to cook food in some areas of the world, but a 2 min. time limit means some serious mods...lol.
How about an insulated box say formed with poly or foam insulation in a box shape insulating an enclosed parabolic mirror (say aluminum foil for instance) focused on the bottom of the block. Make the lid a big lens focused on the top.
Basically trying to trap as much passive energy as possible inside the box with insulation, and focusing the energy as effectively as possible to create melt. (guessing the measure of melt decides the winner.)
  • #38
Sodium or Phosphorus?
How about placing ice in a container with a false bottom and keeping either Sodium or Potassium in the bottom chamber?
Just add water!
  • #39
Wysard, boiling water can't be used. Any additional water used must be at room temp.
  • #40
Also, the lense was one of our ideas but the problem is the experiment is conducted indoors under fluorescent light. So do you think the light would give enough energy.
Another very simple idea was to place the ice in a zip lock bag and drop the bag into a beaker with water at room temperature. Any suggestions?
  • #41
Just add water!
No chemicals can be used at all.
  • #42
You may just choose to keep the zip-loc bag under an open faucet. That does not violate any of the conditions.
Ok, you have got so many people hooked to this thread. Time to take stock of the situation. Think about what all you have at your disposal. So far you have the following you can use (with heat transfer mechanisms):
1. Light (radiation)
2. Pressure (thermodynamics)
3. Fluids (convection and conduction)
4. Air (convection and conduction)
5. Friction (energy conversion, increase in surface area)
Now, the task for you is to pick and combine them in the best possible manner.
13K
