Merging Gravity with the other forces
  • Context: Graduate
  • Thread starter Thread starter VictorMedvil
    Forces Gravity
42 replies · 10K views
VictorMedvil
How mathematically within the confines of mainstream physics would you experts in physics merge Einstein's Field Equations with Quantum Mechanics and Quantum Field Theory? I am looking for a different perspective on this subject usually I get the perspective of "Cranks".
Vanadium 50 said:
If there were an answer to your question we would already have a theory of quantum gravity.
Okay, let me change my question then what are the known problems with merging the two and three, Mathematically.
Linearized GR can be quantized as an effective (non-renormalizable) QFT, where an infinite number of new terms in the Lagrangian are introduced to regularize the theory. So in principle as long as you're only interested in quantizing the weak field limit of GR, quantum mechanics doesn't protest.
What if you quantized gravitomagneticfield in same way electromagnetic field is quantized?
You mean with a Kaluza-Klein theory? a lot of work has been done on this you can look it up.
As an effective field theory, GR is essentially unproblematic. It is non-renormalizable, but this is a much less serious problem than one has thought in the past. Effective field theory means you have an explicit cutoff distance, and accept that you have no theory for distances below that cutoff. Then you assume that at this critical distance all that infinity of imaginable additional terms has some common upper bound of magnitude. Then you can consider the large distance limit. You will find out that the higher-order terms will decrease much faster so that the whole infinity can be safely ignored, and only the lowest order terms are worth to be considered at distances large in comparison with the critical length.
The straightforward candidate for the critical length would be Planck length.
A conceptual problem with this is that to transform GR into a usual field theory you have to break relativistic symmetry. This can be done by enforcing preferred coordinates, with harmonic coordinates as the straightforward choice. This would leave the Einstein EP intact and violate only the Strong EP. Thus, the preferred frame effects would influence only the gravitational field. These effects would, therefore, be similar to dark matter.
  • Love
I do not think it is what I meant. I meant quantisisng gravitomagneticfield same way electromagnetifield is quantized.
That’s not a different theory from GR
Maybe I misunderstood your wording, but quantized gravitomagneticfield is very different from general relativity.
Still seeking a mathematical description, this is all well and good but I wanted to see the math reasons, I always hear the QM,QFT, and GR cannot be fused I would like to see it with my own eyes. Yes, its not renormalizable but how so math please, is it the Reimann curvature of GR or what? Either way I would like to get to the bottom of the issue.
VictorMedvil said:
... this is all well and good but I wanted to see the math reasons, I always hear the QM,QFT, and GR cannot be fused I would like to see it with my own eyes. Yes, its not renormalizable but how so math please, is it the Reimann curvature of GR or what?...
If you want the math with your own eyes, then such a forum cannot really help you. What you need is a serious textbook, which tells you how to do a Feynman diagram, how to write down the corresponding integral, which terms are the problematic ones. The only help you can hope for here would be a recommendation for a good textbook to learn all this, which is not easy because even if many handle the SM, essentially nobody will handle GR as a field theory. More generally, in textbooks, you will find what works, but will not find why other things don't work.
So you are telling me that the inability to merge GR and QM is mainstream however you cannot show how merging the two is impossible, Lame answer!
  • Sad
No one is going to write here a few textbooks for you. Get real.
This is why I don't like this forum, in any other forum there would be someone up to the task.
  • Sad
  • Haha
Can you give me a link to some better forum?
But Iagree with your critisism, I have not got answers to many questions I have asked here. answering these would probably not be hard for someone who knows this stuff.
  • Haha
So why don't you ask someone on any other forum? Again, you are asking to write a whole textbook here, because this issue is technically very involved. Well, unless you have appropriate background in quantum field theory and general relativity, but then you would find the answer long time ago in textbooks you were using...
Try MIT, Harvard, Oxford, Cambridge, etc. They may be able to help. Although, as previously mentioned, if they knew how to do it they would have done, and you wouldn't be here asking the question.
Whatever this is going nowhere someone close this thread.
I gave my answer to this question at Physics Stack Exchange a few years ago. The highest-voted answer there may also help.
The real calculation as you will see is quite difficult, but it was done here for the first time:
http://www.numdam.org/article/AIHPA_1974__20_1_69_0.pdf
Some people claim that string theory has successfully merged gravity and quantum mechanics. However, I have understood that there is no proof of that fact. String theorists seem to have a problem describing the de Sitter universe or the FLRW universe. String theorists have become frustrated in the past two decades.
Loop quantum gravity is another effort. I have the impression that it is almost impossible to calculate anything in their network model, and that Lorentz covariance is a problem.
The non-renormalizability of gravity is often quoted as a problem in a straightforward inclusion of gravity as just one force in QFT.
Another problem is that QFT is formulated in an inertial frame of the Minkowski space. It is not easy to generalize that to the curved spacetime of General relativity.
A black hole is something we do not have in standard QFT. How to handle it?
There are lots of further problems. Steve Carlip has written about this endeavour.
QFT can be formulated in curved spacetime OK, they cannot generate it.
Cheers
Cheers
https://www.physicsforums.com/threa...ments-for-unruh-and-hawking-radiation.978501/
Classical fields seem to work ok in curved spacetime if we do not take into account the backreaction. If we do, then the problem is to find a solution for the Einstein equations with an arbitrary matter field, and that problem has been open since 1915.
In the semiclassical regime without a backreaction, there is the dispute: does Unruh or Hawking radiation exist?
QFT in curved spacetime would require gravitons, or some completely new insight. Some string theorists claim that they can handle it, but many people are sceptical.
I am right now doing research on this: what is the relationship between classical fields in curved spacetime and QFT.
VictorMedvil said:
I don't see the incompatibility of QM with GR...
Don't take it personal, but what you wrote there shows that you have no idea what you are talking about. ##R## is not a radius, and Einstein equation is not an algebraic equation, it's tensorial so you can't just simply divide by ##g_{\mu\nu}##.
Then what is that R?
Scalar curvature. You should know that if you try to manipulate this equation.
but isn't scalar curvature just the two principal radii? where
\rho_1,\,\rho_2
are the principal radii of the surface. For example, the scalar curvature of the 2-sphere of radius r is equal to 2/r2.
Not in four dimensions. General definition is ##R=R^\mu_{\phantom{\mu}\mu}##. You should really study some textbook on very basics before you try to learn about quantum gravity.
