Merging two files using C program
  • Thread starter Thread starter kthouz
    files Program
To merge two files in C, the process involves using the `fopen` function to open the first file in read mode and the second file in read mode, while opening a third file in write mode to store the merged content. The basic steps include reading from both input files and writing the content to the output file, followed by closing all files. While pointers may not be necessary for simple file merging, they can be useful for managing buffers and file sizes. An example program demonstrates opening files, reading data into a buffer, and writing that buffer to the merged file. Error checking is recommended for robustness. Alternative methods, such as using system calls or DOS commands, can also achieve file merging but may sacrifice portability across different operating systems.
kthouz
How can i use c program two merge two files. Does it have to do with "pointers" or am going wrong!
Technology news on Phys.org
Open file "first" and file "second" in read mode using the fopen function; also open file "merged" in write mode using the fopen function; then read from files "first" and "second" and write what you read to file "merged"; then close all three files and you are done.
I'm sure there are more details involved that may or may not require pointers, depending on the exact nature of your assignment, but these basic steps do not use them.
Thanks for your answer. Just can you please give a me an example of a sample program to open another one because it's the first time i hear about fopen function. But don't worry tell me ill figure it out!
Code:
FILE * fp;
fp = fopen("filename.txt", "wt");
fprintf(fp, "Hello fopen\n");
fclose(fp);
See http://www.cplusplus.com/reference/clibrary/cstdio/fopen.html
What platform are you programming in? You can make use of the linux system calls - open(), read(), and write(). Open() has the O_APPEND flag that opens a file in append mode, thereby adding data to the end of the file. You can use this to merge your two files. Read the manual pages of the respective functions for a detailed description. Then again fopen() does have th "a" flag for append.
I don't imagine you're allowed to be so sneaky as to make an OS call, like "copy first+second merged" (DOS./cmd) or "cat first second > merged" (bash)?
This is a somewhat 'tedious' but portable way to do it in C.
Opening the primary file for 'update' rather than 'append' has the effect of removing the EOF marker before appending new data.
#include <stdio.h>
#include <stdlib.h>
#include <io.h>
#ifdef BYTE
#undef BYTE
#endif
#define BYTE unsigned char
BYTE *buf2;
long size;
FILE *fp1, *fp2;
//open file-1 for update, file-2 for read
fp1=fopen(fname1,"a+");
fp2=fopen(fname2,"rb");
//get size of file-2
fseek(fp2,0,SEEK_END);
size=ftell(fp2);
rewind(fp2);
//allocate buffer, read-in file-2
buf2=(BYTE *)malloc((size_t)size);
fread(buf2,size,1,fp2);
//write the buffer to (end of) file-1
fwrite(buf2,size,1,fp1);
//clean-up and close
free(buf2);
fclose(fp1);
fclose(fp2);
It'd be a good idea to do some error checking if you use this code for anything serious...
message
Give the program to merge two files into a single one ic C Programming
Dos command:
copy filein1/b+filein2/b fileout/b
If this is a windows console program, you might want to use CreateFile and related commands instead fopen, but the program would be less "portable" to other OS's.
Which part of
#include <stdio.h>
#include <stdlib.h>
#include <io.h>
#ifdef BYTE
#undef BYTE
#endif
BYTE *buf2;
long size;
FILE *fp1, *fp2;
size=ftell(fp2);
rewind(fp2);
free(buf2);
fclose(fp1);
fclose(fp2);
did you not understand?
  • · Replies 33 ·
