Mesh Analysis w/ Supermesh and "different" current direction
17 replies · 3K views
eehelp150
Find power absorbed by resistor, capacitor and inductor. Find the total complex power absorbed by all the loads.[/B]
KVL/KCL
I want to solve this using Mesh analysis. There is a supermesh where the 5A source is, so I start it like this:
How do I assign the mesh currents? I1 and I2 are going in different directions.
KVL/KCL
You have been given reactances of the reactive elements while the sources seem to be dc. If you want to calculate the complex power, the sources must be ac. Is that the complete circuit diagram you have? Aren't the phase angles of the sources mentioned?
Sorry about that, the phase angles are 0 degrees.
You can assign mesh currents in any direction you like so long as you write the mesh equations according to the resulting definitions. That is, when you write the equations pay attention to the defined current directions. The alternative is to just apply your wrote procedure and then interpret the results in terms of the currents you "really" want. That is, extract your ##I_1## and ##I_2## from the mesh currents after solving for the mesh currents; signs imply directions.
-I1(10+j20) + 6V + I2(-j2) = 0
I1 + I2 = 5
Are these correct?
gneill said:
Yes, those look good!
I1 = (-15-26i)/53
I2 = (280+26i)/53
Correct?
gneill said:
Yup.
Finding the power absorbed by the inductor/resistor/capacitor is simply 6V * I? Where I = I2 for the capacitor and I1 for the resistor and inductor?
The 6 V voltage source is not across any of the individual components. Use the currents through the components and the component impedances. Remember the DC version P = I2R? There's an AC version of that. Hint: One of the I's in I2 should be the complex conjugate.
So basically (I)(I*)(Z)
Correct. This works because with a little rearrangement we can see:
P = (I)(Z)(I*) = (V)(I*)
Capacitor: -j2 * I2 * I2*
Resistor: 10 * I1 * I1*
Inductor: j20 * I1 * I1*
Correct?
Total would be everything added up?
gneill said:
Yes, that looks fine.
I ended up getting these values, would you mind double checking?
Resistor = -1.61 + 2.8i
Capacitor = 10.37 - 55.3i
Inductor = -5.6 - 3.21i
What is the proper way to display these values? Converting to complex power(S = sqrt(P^2+Q^2))?
Just out of curiosity, would the voltage across resistor be -I1 * 10ohm because of the direction?
Can you show your calculations in detail? I'm immediately suspicious because the power you found for the resistor turned out to be complex; Resistors have no reactance and can only dissipate real power no matter if the current is complex or not. Inductors and capacitors have no resistance and cannot dissipate real power, yet your results show them both dissipating some real power.
For display of complex power in general I'm partial to the rectangular form so that I can immediately see the real and reactive parts. But some prefer to see the magnitude of the apparent power and the power factor. When in doubt provide both.
You need to specify how you will interpret a voltage before you even calculate it. That is, establish a reference point or orientation on your circuit diagram for interpretation of the voltage. Otherwise you can only talk about the magnitude of the potential change. When we write KVL equations, for example, we agree on interpreting the potential change in light of the arbitrarily decided current direction and direction of our "KVL walk" around the loop.
In the figure below, the voltage ##V_R## across the resistor would be positive in one interpretation and negative in the other. Yet it's the same potential drop. It's all in how you define the "measurement" on the circuit diagram.
Forgot to use conjugate.
New values:
Resistor: 3.2W
Capacitor: -56.3 VAR
Inductor: 6.4 VAR
