Mesh current analysis with complex impedances
43 replies · 6K views
shaltera
Use mesh current analysis to determine I1
Loop 1
47i1+j100(i1+i2)-12=0
(47+j100)i1+j100i2=12
Loop 2
-j75i2+j100(i1+i2)-10=0
j100i1+j25i2=10
j100i1+j25i2=10 (-4)
-j400i1-j100i2=-40
-j400i1+(47+j100)i1=-38
j400i1-i1(47+j100)=38
(-47-j300)i1=38
Is it correct?
Loop 1
Loop 2
j100i1+j25i2=10
-j400i1-j100i2=-40
-j400i1+(47+j100)i1=-38 <---- check that value
(-47-j300)i1=38
Is it correct?
A slight problem with the voltage value indicated above.
40-12=28
Well spotted
shaltera said:
40-12=28
Well spotted
Right. Now finish, isolating i1 and writing it in a standard form.
Thanks.I decided to use matrices to solve this problem.I hope matrices is correct
For i1 I have -0.0557<84.63deg
Is it correct?
Is it correct?
No, it doesn't match what I find.
(47+j500)i1=-28
i1=(-28)/(47-j500)=(-28)/(sqroot(472+5002))tan -1(500/47)=
-28/502.2<84.63deg=-0.05557<84.63deg
shaltera said:
(47+j500)i1=-28
i1=(-28)/(47-j500)=(-28)/(sqroot(472+5002)tan -1(500/47)=
Show your algebra beginning from where you left off here in your first post:
##j400 i_1 - (47 + j100) i_1 = 28##
For mesh A
-12+47i1+j100(i1+i2)=0
47+j100i1+j100i2=12
For mesh B
-10-j752+j100(i1+i2)=10
j100i1+j25i2=10
Therefor
j100i1+j25i2=10 (x(-4))
(47+j100)i1+j400i1+j100i2-j100i2=12-40
(47+j100)i1-j400i1=-28
47i1+j100i1-j400i1=-28
(47-j300)i1=-28
i1=-0.922<80.09deg
hope is correct
shaltera said:
For mesh A
47+j100i1+j100i2=12 ##~~~~##<--- lost your parentheses here...
(47+j100)i1+j100i2=12 ##~~~~##<--- but recovered them here
The final expression is okay.
For mesh B
-10-j752+j100(i1+i2)=10 ##~~~~~##<--- Voltage source appears twice!
j100i1+j25i2=10 ##~~~~~##<---- But now the duplicate's gone!
Therefor
j100i1+j25i2=10 (x(-4)) = -j400i1 - j100i2 = -40
(47+j100)i1+j400i1+j100i2-j100i2=12-40 <--- What happened here?
(47-j300)i1=-28
I think you tried to subtract the mesh B equation from the mesh A equation, but didn't change the sign of the i1 term.
j100i1+j25i2=10 multiply by (-4)
-j400i1-j100i2=-40
then I add equation for mesh A to B
(47+j100)i1-j400i+j100i2-j100i2=12-40
+j100i2-j100i2=0
Therefor
47i1-j300i1=-28
(47-j300)i1=-28
-j400i1-j100i2=-40
+j100i2-j100i2=0
Therefor
47i1-j300i1=-28
(47-j300)i1=-28
Okay, that looks better. Continue.
i1=-=-28/303.65<80.096=-0.0922<80.096
As well should I mention that I have used KVL to solve this problem
You should incorporate the sign of the numeric part into the angle since the numeric part is the magnitude of the complex value, and magnitudes are always positive (absolute) values. Your angle appears to be off by one degree... typo?
Yes, that was clear from your equations.
i1=-28/(47-j300)=-28/sqr (472-3002)tan-1(-300/47)=-28/303.65<80.096=0.093<-81.10deg
10=j100i1+j25i2 =100x1<90x0.093<-81.10+j25i2
10=9.3<(90-81.10)+j25i2
10=9.3cos(9)+j9.3sin(9)=9.19+j1.439+j25i2
10=9.19+j1.439+j25i2
-0.81+j1.439=-j25i2
1.651<-0.94/-j25i2=1.651<-0.94/25<90=0.066<-90.94
The angle you've found for the denominator doesn't reflect the sign of the argument of the arctan function. Note that the "-" is associated with the numerator of the argument, -300. So the angle should end up in the [STRIKE]third[/STRIKE] fourth quadrant. Also the angle value is off by a degree (typo?).
Next, the negative sign on the numerator (-28) has disappeared. It should get rolled into the final angle... think of the numerator as 28 ∠ ±180°. Or, perhaps more easily, make the numerator positive to begin with (multiply top and bottom by -1 before you begin).
Calculated differently:
(-28/47-j300)(47+j300)/(47+j300)=(-1316-j8400)(2209-j290000)=(-1316-j8400)/92209
(-1316/92209)-(j8400/92209)=-0.0142-j0.091=0.092<98.86deg
Good, but the angle should be negative. The two components of the current are both negative, putting the angle in the third quadrant.
I simple used Pythagorean theorem and arctan
sqr((-0.0142)2+(-0.091)2)tan -1(-0.091/-0.0142)=
0.092<-98.86deg
CASIO fx-83ES, calculated arctan (0.091/0.0142) as 81.25deg. Online calculator gave me result:98.86
Which one is correct?
0.092<-98.86deg
Arctan can't "see" the two negative signs of its argument; they cancel when you do the division. It's up to you, the user, to make sure that the angle ends up in the right quadrant. I'm sure you covered the domain and range of the trig functions in one of your previous courses dealing with trigonometry.
As an alternative to arctan, if your calculator has an atan2(y,x) function, then it takes both arguments separately and always returns the right result.
I didn't know how to express it at the beginning but that's what I had in mind
arctan -1 (300/47)
Look like online calculator is right :)
0.092<-98.86deg
Ok.How about calculations in a second equation (i2) in P17?Is it correct?
81.13° for that argument to arctan. The 98.86 value looks like the result for -28/(47 - j300).
10=j100i1+j25i2
10=9.3<(90-98.86)-j25i2=100x1<90x0.093<-98.86+j25i2
10=-9.3cos(9)-j9.3sin(9)=-9.19-j1.439+j25i2
10=-9.19-j1.439+j25i2
shaltera said:
10=j100i1+j25i2
It's getting messy plugging in numbers and then rearranging while calculating. Why not start by clearing out the j's from the right hand side? Multiply through by -j.
##-j10 = 100 i_1 + 25 i_2##
Isolate ##i_2## and then then start plugging in values.
i2=(-100i1-j10)/25=-10(10i1-j)/25=-2(10i1-j)/5
