Migration Path of Electrons in Ionized Air (Gamma Radiation)
The discussion revolves around the behavior of electrons accelerated by gamma radiation in ionized air, focusing on the emission of gamma photons, energy transfer during collisions, and the resulting electron paths. Participants explore theoretical aspects, calculations related to photon emissions, and the implications of these processes in a practical context.
  • One participant questions the assumption that photons emitted have an energy of exactly 1.9 MeV, suggesting that achieving a high number of photons per electron may be unrealistic.
  • Another participant agrees that calculating the number of collisions using the derivative of a decreasing exponential function is feasible.
  • Participants discuss the maximum energy transfer during collisions, noting that actual energy transfer can be lower and that pair production may occur.
  • There is speculation about the possibility of calculating charge movement to develop a current profile along the beam.
  • Questions arise regarding the path electrons take after being released, with some suggesting they ionize other atoms and emit bremsstrahlung, while others inquire about the potential difference balance in the system.
  • One participant expresses uncertainty about the origin of the gamma photons and discusses the conditions under which gamma radiation is generated, referencing experiences with electron acceleration and beam loading.
Participants express differing views on the energy of emitted photons and the feasibility of achieving high photon emission rates. There is no consensus on the specifics of electron paths or the mechanisms balancing the potential difference in the system.
Some participants highlight the complexity of energy transfer during collisions, noting that factors such as photon energy and material properties may influence outcomes. There are unresolved questions regarding the distribution of energy transfer and the behavior of electrons in the presence of gamma radiation.
This discussion may be of interest to those studying particle physics, radiation interactions, and the behavior of ionized gases, particularly in experimental and theoretical contexts.
sapratz
I would love some clarification on a gamma ray process. This is what I understand so far:
Electrons are accelerated at 19MeV at a cathode which is releasing gamma ray photons with an energy of 1.9MeV. Is it possible to generalize the emission number of photons (roughly) to be equal to the 19MeV/1.9MeV (per electron fired)?
Assuming that is okay, we can move on to the range of the gamma photons in air. If I have calculated the decreasing exponential curve describing the number of photons present at each point in the gamma ray beam, can I take the derivative of this function spatially to be able to calculate the number of collisions at any given point?
Assuming that's alright, I have the number of collisions happening at any given point and I have calculated that the interactions are mostly compton (from high energy photons). I used the generalized for for maximum energy transfer:
Emax = 1.9MeV(2*(3.718/8.436)) = 1.67MeV transferred to each electron, with the remainder producing a photon at a frequency of 5.56e19Hz.
(We are only looking at the first wave of interactions, not the successive photon interactions)
so we have the energy of an ionized electron and the number of electrons that are being ejected at any given point from the beam.
My REAL question (assuming all that other stuff is correct) is can we calculate the charges moving at each point to essentially develop a current profile at any given point along the beam?
And also, just conceptually, does anyone have any idea as to the path the electrons will take after they are released? how does the system balance the potential difference developed? Does it arc to ground, or does it loop back to the start of the beam?
Thanks,
Scott
Why should it emit photons with exactly 1.9 MeV?
You want 10 1.9MeV-photons per incoming electron? I think it would be a great achievement if you get something close to 1.
Sure.
This is the maximal energy transfer, the actual energy transfer can be lower.
In addition, you get pair production.
It should be possible to calculate the estimated rate of electrons everywhere.
They ionize some other atoms, emit some bremsstrahlung and so on - the typical processes for fast electrons.
You create a lot of free charges in ionizing processes. I guess those are sufficient to balance the currents.
I don't know how to navigate the the forum very well, so I'll just copy paste, but thanks for the response.
-The particle guys gave us that number, it's the average energy per photon released from the accelerator. Why do you think this number is odd?
-Where does the conservation of energy come into play here? I assumed that since the electrons were colliding with an energy and were experiencing breaking radiation until absorption they were going to emit photons of equal energy. That's where I got the number.
- how much lower is the energy do you think? does the percentage transferred depend on the amount of energy contained in the photon? i was trying to determine what the angle of ejection was to calculate the amount of energy transferred, but I couldn't find anything on it. I didn't know if there was a distribution of probabilities based on the element/compound type but I was having trouble.
- so there is no "path" that the electrons will flow? we are essentially trying to determine the magnetic field generated by the resulting interactions from the gamma interactions. Do the electrons tend to correct the potential difference by being absorbed back at the earlier parts of the gamma radiator? basically do the ions arc back to the positive ions created?
thanks
You can quote things by putting [noparse]
[/noparse]-tags around them:
[noparse]
text
[/noparse] becomes
text
As an average energy, it is fine. I would expect a very broad spectrum.
The broad spectrum is a partial answer: You get photons of different energy, too. In addition, some (most?) energy is lost in the material, only some fraction will get emitted as radiation. And that radiation is undirected.
Photon energy losses in the Compton effect can be anything from zero to the maximal energy loss. Correspondingly, electrons can get an energy from zero to the maximal energy.
The photon energy is relevant, as it determines the maximal energy transfer and the scale of the whole process.
This is the standard Compton effect formula.
I am sure this has been studied (and calculated), but I don't know where.
Well, they tend to go in the direction of the initial gamma ray, with a wide spread around that direction.
You might get some small net current along the beam direction (if you form a beam of gamma rays).
I doubt this. There are so many other electrons to balance the charges.
I am still unsure where the gamma photons are coming from. It appears that this is entirely from the electrons that was accelerated to 19 MeV? Over what distance are they accelerated to give that 1.9 MeV gamma? I've accelerated electrons to 8 MeV over a distance of about 10 cm, and we detect no gamma. In fact, what we detect is "beam loading" in the RF cavity (i.e. it "sucked" in EM field).
Now, if the 19 MeV electrons were to crash onto, say, the stainless steel pipe or some high-Z material, then I definitely know those generate lots of gamma via Bremsstrahlung (I used to deal with accelerator safety and shielding issues a lot!).
Zz.
Zz.
Yes, the 19MeV electrons are colliding with a very High-Z material and that is how the 1.9MeV photons are being produced
Then you should have given this vital info, because it also means that you have left out a very important piece of information: the thickness of this material.
In such a Bremsstrahlung radiation, most of the radiation emitted is along the direction of the path of the electrons, i.e. the forward direction. How much of these gamma photons that got through is, obviously, a direct function of the thickness of the material due to the attenuation effects inside the material.
So as you have described the problem, there is at least one major piece of info that is missing.
Zz.
Zz.
120mil tantalum :)
so the average energy of the gamma photons released is 1.9MeV and the number that is actually released is dependent upon the thickness and density of the plate material? That makes sense I guess. Any ideas on some formulas for this calculation?
Also, do you think there will be current traveling on the plate due to electron interactions?
  • · Replies 0 ·
