Why Did Water Droplets Fail to Suspend in Millikan's Early Experiment?
Millikan's early experiment using water droplets failed to suspend them due to evaporation, which caused the droplets to rise as gas. The gravitational force was insufficient to hold the gas particles in place. In contrast, his successful oil droplet experiment involved charging oil droplets and balancing electric and gravitational forces to determine the elementary charge, which was found to be 1.6 x 10^-19 C. The evaporation of water droplets introduced significant variability in mass and terminal velocity, complicating charge determination.
  • Understanding of Millikan's oil drop experiment
  • Knowledge of electric force and gravitational force balance
  • Familiarity with concepts of mass, terminal velocity, and charge
  • Basic principles of evaporation and gas behavior
  • Study the principles of Millikan's oil drop experiment in detail
  • Research the effects of evaporation on small droplets
  • Learn about the relationship between mass, terminal velocity, and charge
  • Explore the physics of electric fields and forces on charged particles
Students of physics, educators teaching electromagnetism, and researchers interested in experimental methods for measuring charge and forces on small particles.
krbs
When Millikan first performed this experiment, he used water droplets instead of oil. He found he could not suspend the droplets; they would start to move up. Why did this happen?
N/A
The water droplets would have been so small that they evaporated and rose as a gas. The gravitational force wouldn't be strong enough to hold the gas particles in place.
Could you describe to me Millikan's experiment once? I mean, in your own words.
Oil was sprayed through an atomizer into an initial chamber, which gave the oil a charge. A droplet of oil would drip through a hole in the bottom of the chamber into a second chamber separated by two horizontal parallel plates. He could adjust the potential difference between the plates so that the electric force on the oil balanced out with the force of gravity acting on it (net force zero.) The mass of the droplet was found by finding the terminal velocity of the oil after shutting off the power supply. He could then determine charge by setting electric force equal to the force of gravity and solving for charge. He determined that the smallest charge measured was 1.6 x 10^-19 C and that all of the charges measured were multiples of this base charge. Thus elementary charge was determined.
The water droplet would have gradually evaporated, reducing its mass. This would make it difficult to suspend because he'd have to keep adjusting potential difference between the plates. Determining charge would be difficult because he couldn't be certain of the mass. He probably couldn't determine a precise terminal velocity of the droplet either because he couldn't be certain what position it fell from. The results would be skewed because the measurements were so imperfect.
13K
