Finding Minimum and Maximum with Trigonometric Functions: y=sin x+cos x
  • Thread starter Thread starter Karol
    Max
The discussion focuses on finding the minimum and maximum values of the function y = sin(x) + cos(x) using its first derivative. The first derivative is calculated as y' = cos(x) - sin(x), which equals zero at x = π/4 + nπ, indicating critical points. The maximum values occur at x = π/4 + 2kπ and the minimum values at x = 5π/4 + 2kπ, where k is an integer. The transformation of the function into the form y = √2 sin(x + π/4) is also highlighted as a useful approach for determining these extrema.
  • Understanding of trigonometric functions, specifically sine and cosine.
  • Knowledge of calculus, particularly differentiation and finding critical points.
  • Familiarity with periodic functions and their properties.
  • Ability to manipulate trigonometric identities, such as sin(a + b).
  • Study the application of the first derivative test in determining local maxima and minima.
  • Learn about the transformation of trigonometric functions, specifically using identities like sin(a + b).
  • Explore the implications of periodicity in trigonometric functions on their extrema.
  • Investigate the graphical representation of y = sin(x) + cos(x) to visualize its maxima and minima.
Students studying calculus, particularly those focusing on trigonometric functions and their applications in optimization problems. This discussion is also beneficial for educators seeking to clarify concepts related to derivatives and extrema in trigonometry.
Karol
Minimum/Maximum occurs when the first derivative=0
$$y=\sin{x}+\cos{x}~\rightarrow~y'=\cos{x}-\sin{x}$$
$$y'=0:~\rightarrow~\cos{x}=\sin{x}~\rightarrow~x=\frac{\pi}{4}+n\cdot \pi$$
It's not correct
Karol said:
It's not correct
Yes it is.
What makes you think it is not correct?
$$y(max)=45^0+2\pi k,~y(min)=225^0+2\pi k$$
Karol said:
$$y=\sin{x}+\cos{x}$$
There's a nice trig formula that gives:
##\sin x + \cos x = \sqrt{2}\sin(x + \frac{\pi}{4})##
Which hopefully settles the issue, if nothing else does.
Just to add some middle steps
\sin(x) + \cos(x) = \sqrt{2}[\sin(x)/\sqrt 2 + \cos(x)/\sqrt 2] = \sqrt 2 [\sin(x)\cos(\pi/4) + \cos(x)\sin(\pi/4)] = \sqrt 2 \sin(x+ \pi/4).
## y'=0:~\rightarrow~\cos{x}=\sin{x}~\rightarrow~x=\frac{\pi}{4}+n\cdot \pi ##
Both agree. The original says, there is a max or min at ##\frac {\pi}{4} + n \pi \ \ \ ie. \frac {\pi}{4}, 5 \frac {\pi}{4}, 9 \frac {\pi}{4}, 13 \frac {\pi}{4}, etc. ##
The later simply separates them into max and min points with maxima at ## \frac {\pi}{4}, 9 \frac {\pi}{4}, 17 \frac {\pi}{4}, etc ##
and minima at ## 5 \frac {\pi}{4}, 13 \frac {\pi}{4}, etc. ##
Your first answer was not wrong, just inadequate if you were required to list them separately.
  • · Replies 40 ·
  • · Replies 18 ·
