DaveC426913
2025 Award
- 24,698
- 9,103
I have added a closeup to the above post.Danger said:Right, then... I see it now.
Heh. Pun jumped right over my head.Danger said:You got to admit that the 'bass' pun wasn't too bad, though...?
There is turbulence from a babbling brook, yes, but that's not what I'm concerned about. The motion of the whole device is a bit jumpy due to friction and imperfect gears. Even as it is, the boat jumps and jerks a little. Bendy wires would greatly magnify this.Danger said:Although it might not matter to the design, is there turbulence of any sort in this pond? I ask only because of you mentioning the boat flopping around on a flimsier support structure.
The boat is not attached to the yellow gear at all. It is simply on a beam that sticks out from the main vertical axle (the red clippy bit in the centre). The fish axle is free to rotate, but the boat is held rigidly, always trailing the fish by 90 degrees.Danger said:Also, if the boat and the fish are synchronized in revolutions around the centre,
You are good! It is like having a conversation with my own thoughts!Danger said:you could link a loose piece of thread between them to make it appear as if the fish has already been hooked. It would have to be disproportionally thick, though, to make it visible from a distance.
I'd thought of the string. The one problem with it is that there is nowhere to attach the string to on the fish axle. Every part of the axle/fish is rotating. It is theoretically possible to attach the string with a loose loop around some part of the axle but if that loop ever gets ... uh ... fricted ... it will seize and wind up on the axle like a scarf caught in a bicycle wheel.
