Minimum distance of functions in a metric space
8 replies · 3K views
copacetic
A metric on C[0,1] is defined by:
[tex]d(f,g) = ( \int_0^1 \! (f(x) - g_t(x))^2 \, dx )^{1/2}[/tex]
Find t e R such that the distance between the functions [tex]f(x) = e^x - 1[/tex] and [tex]g_t(x) = t * x[/tex] is minimal.
Given above
The first thing I did was multiply the inner part of the integral out then evaluate it:
[tex]( \int_0^1 \! (e^x-1) - (tx))^2 dx )^{1/2}[/tex]
[tex]= ( \int_0^1 \! e^{2x} - 2e^x - 2te^xx + 1 + 2tx + t^2x^2 dx )^{1/2}[/tex]
[tex]= (\frac{1}{2}e^2-\frac{1}{2} - (2e - 2) - 2t(e) + 1 + 2t(\frac{1}{2}) + t^2(\frac{1}{3}) )^{1/2}[/tex]
[tex]= ( \frac{1}{2}e^2 + \frac{5}{2} - 2et + t + \frac{1}{3}t^2)^{1/2}[/tex]
But I'm not sure I did that right, because now I don't know where to go from here. Any tips?
So the distance between f and g depends on t. You might even say it's a function of t... do you know how to minimize a function that has only a single variable?
I would need to find the first derivative, find the roots and then check their sign in the second derivative. Can I do this without the square root around the entire function? Because with it the derivative is enormous and I'm not sure how I'd go about solving it for 0.
It's a pretty common technique to use that [tex]\sqrt{a}<\sqrt{b}[/tex] is true exactly when [tex]a<b[/tex] (assuming everything is positive here), so to minimize a function [tex]\sqrt{f(x)}[/tex] it's enough to minimize [tex]f(x)[/tex] itself (the same thing holds true for maximizing)
Even without using that though, by the chain rule the only difference is that you would have the function again in the denominator, and you can clear that out when you try to solve for the derivative equal to zero
You should not need to integrate- you find the derivative of a vector by differentiating and by the "Fundamental Theorem of Calculus", the derivative of [itex]\int_a^x f(t)dt[/itex] is just f(x) itself.
This isn't really a fundamental theorem of calculus situation
Ok thanks, in the end I have
[tex]\frac{2}{3}t - 2e + 1 = 0[/tex]
[tex]t = 3e - \frac{3}{2}[/tex]
Double check that. It looks like you are integrating x*e^x to get e. That's not right.
Woops! You're right, I had x*e^x instead of x*e^x-e^x. Well that got rid of the nasty e now I'm left with t=3/2. Thanks!
