Minimum Force to Make an Object Move
2 replies · 59K views · last reply
uchicago2012
A 6 kg object sits on a horizontal surface with coefficient of friction = .8. What is the minimum force (not necessarily horizontal) necessary to make the object slide?
Fsmax = u * Fn
where Fsmax is the force that must be overcome to make an object move, u is the coefficient of friction, and Fn is the normal force.
I was just wondering if this seemed correct:
Fg = -58.8 N (mass * g) so
Fn = 58.8 N
I'm not clear on when exactly one can make the assumption that Fg = Fn
but then using that value of Fn I calculated Fsmax, so the minimum force necessary to make the block move is any force greater than Fsmax.
You need to overcome the force of friction.
The force of friction is
Ff=(coefficient of friction)(weight of object in Newtons)
Ff=(.8)(6*9.81)
Ff=(.8)(58.86)
Ff=47.088N
I think :D
One can always make the assumption that, if the acceleration in some coordinate direction is zero, then by Newton's second law, the sum of all forces acting along that direction must be zero.
This condition for static equilibrium is the foundation for all introductory statics problems.
