MHB How Can We Find the Minimum 2-Norm of Ax-y Using an Orthogonal Matrix?
  • Thread starter Thread starter mathmari
    Minimum
The discussion focuses on finding the minimum 2-norm of the expression \( \|Ax - y\|_2 \) using the decomposition \( A = QR \), where \( Q \) is an orthogonal matrix and \( R \) is an upper triangular matrix. The participants derive that the minimum can be expressed as \( \|(Q^Ty)_{n+1}^m\|_2 \) for any \( y \in \mathbb{R}^m \). They demonstrate the minimization process by rewriting \( Rx \) and applying properties of orthogonal matrices, leading to the conclusion that the minimum occurs when \( Ux = (Q^Ty)_1^n \). The discussion confirms that this approach is valid due to the rank conditions of \( R \) and \( U \).
mathmari
MHB
Hey! :o
Let $A = QR$, where $Q$ is an orthogonal ($m\times m$)−matrix and $R$ is an upper ($m\times n$)-triangular matrix of rang $n$ ($m>n$).
I want to show that $$\min_{x\in \mathbb{R}^n}\|Ax-y\|_2=\|(Q^Ty)_{n+1}^m\|_2, \ \forall y\in \mathbb{R}^m$$
It is $(a)_k^l=(a_k, \ldots , a_l)^T$ if $a=(a_1, \ldots , a_l)^T\in \mathbb{R}^l$.
I have done the following:
\begin{align*}\min_{x\in \mathbb{R}^n}\|Ax-y\|_2&=\min_{x\in \mathbb{R}^n}\|QRx-y\|_2=\min_{x\in \mathbb{R}^n}\|QRx-QQ^{-1}y\|_2 \\ & =\min_{x\in \mathbb{R}^n}\|Q(Rx-Q^{T}y)\|_2=\min_{x\in \mathbb{R}^n}\|Rx-Q^{T}y\|_2\end{align*}
(We have used here the properties of an orthogonal matrix.)
How could we continue? How can we find that minimum? (Wondering)
Mathematics news on Phys.org
Hey mathmari!
We can write $Rx$ as $\binom U0x$ where $U$ is an up upper triangular nxn matrix of rank n, and 0 is a zero matrix, can't we? (Wondering)
It means that:
$$\|Rx-Q^{T}y\|^2
= \|Ux-(Q^{T}y)_1^n\|^2 + \|0-(Q^{T}y)_{n+1}^m\|^2
Can we solve it now? (Wondering)
I like Serena said:
Hey mathmari!
It means that:
$$\|Rx-Q^{T}y\|^2
Ah ok! We have that \begin{align*}\|Rx-Q^{T}y\|_2^2&=\left \|\begin{pmatrix}U \\ 0\end{pmatrix}x-\begin{pmatrix}(Q^T)_1^n \\ (Q^T)_{n+1}^m\end{pmatrix}y\right \|_2^2 =\left \|\begin{pmatrix}Ux-(Q^Ty)_1^n \\ 0-(Q^Ty)_{n+1}^m\end{pmatrix}\right \|_2^2 \\ & =\|Ux-(Q^{T}y)_1^n\|_2^2 + \|(Q^{T}y)_{n+1}^m\|_2^2\end{align*}
Therefore, we get $$\min_{x\in\mathbb{R}^n}\|Rx-Q^{T}y\|^2=\min_{x\in\mathbb{R}^n}\{\|Ux-(Q^{T}y)_1^n\|_2^2 + \|(Q^{T}y)_{n+1}^m\|_2^2\}$$
This is minimized for that $x$ for which it holds $Ux=(Q^{T}y)_1^n$ and so we get $$\min_{x\in \mathbb{R}^n}\|Ax-y\|_2^2=\|(Q^{T}y)_{n+1}^m\|_2^2\Rightarrow \min_{x\in \mathbb{R}^n}\|Ax-y\|_2=\|(Q^{T}y)_{n+1}^m\|_2$$ right? (Wondering)
Yep.
And that is possible because $R$ is of rank $n$, and therefore $U$ is as well, making it an invertible matrix. (Nod)
Ok! Thanks a lot! (Yes)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
