Minimum Surface Charge Density for Spark Creation
3 replies · 14K views
m84uily
A spark occurs at the tip of a metal needle if the electric field strength exceeds 3.0x10^6 N/C.
What is the minimum surface charge density for producing a spark?
int(EdA) = (Qin) / e0
I imagine the surface as a cylinder with the electric field going parallel to it.
int(EA) = backface + side + frontface = EA + EA = 2EA
E = 3.0x10^6 N/C
A = (pi)r^2
(2)(3.0x10^6 N/C)(pi)r^2 = (Qin) / e0
(e0)(2)(3.0x10^6 N/C)(pi)r^2 = Qin
Then, I don't want r is! I've probably gone about solving this all wrong, thanks in advance for your help.
You know that free charges can not exist inside a metal so what do you mean on Qin?
The surface charge density is not uniform on the surface of a needle, and the tip of a needle is not flat.
You also might remember that Q/ε0 electric field lines originate from a unit positive charge, and the electric field strength is the number of field lines traversing a normal unit surface.
So the electric field strength given is related directly to the surface charge density on the metal.
ehild
You definitely cleared up a lot for me! Thanks!
So:
Q/ε0 = E
Q = E(ε0)
