Miscellaneous Definite Integrals
7 replies · 2K views
lostminty
show that
[itex]\int^{∞}_{0}\frac{sin^{2}x}{x^{2}}dx= \frac{\pi}{2}[/itex]
consider
[itex]\oint_{C}\frac{1-e^{i2z}}{z^{2}}dz[/itex]
where C is a semi circle of radius R, about 0,0 with an indent (another semi circle) excluding 0,0.
curve splits into
C1, line segment from -R to -ε
C2, semi circle z=εeiθ θ goes from ∏ to 0
C3, line segment from ε to R
C4, semi circle z=Reiθ θ goes from 0 to ∏
function is holomorphic in/on C. so integral =0
for C4, applying limit R > infinity integral = 0
C3. really stuck here
I sub in the value of z
to get
[itex]\int^{0}_{∏}\frac{1-e^{i2e^{iθ}}}{ε^{2}e^{2iθ}}εe^{iθ}[/itex]
but I can't take the limit ε -> 0 of this since there's an ε on the denominator
You forgot an ε in the exponent and a factor of i.
$$\int^0_\pi \frac{1-e^{i2\varepsilon e^{i\theta}}}{\varepsilon^2 e^{2i\theta}} i\varepsilon e^{i\theta}\,d\theta$$
Thank you. I was half awake when I wrote that.
I just don't know how to get that ε out from the denominator, I cannot take the limit otherwise.
Try expanding the exponential and the numerator as a series.
The teacher gave me a hint, use l'hospital's Rule, which isn't clear to be possible since i forgot to add in the limit
I'm not sure what you mean by that. In any case, either way should work. The numerator is first-order in ε. Along with the factor of ε from dz, it cancels the ε2 in the denominator, so you will get a finite result.
I mean, differentiating the top and bottom before taking the limit.
as in a taylor series?
I still have no clue what you mean.
