Missing component to get the impendance ohmic
  • Thread starter Thread starter Lindsayyyy
    Component
15 replies · 2K views
Lindsayyyy
Hi, following graphic is given (attachment)
I tried it with the following equation:
[tex]\omega iL-\frac i {\omega C} + X =R[/tex]
but I don't get to the solution, is this the right attempt? If yes, I'll try later on again, have to go to the university right now.
Thanks for the help :smile:
ah sorry, I was in a hurry. I shall find the missing component so that the impendance/resistance of the series connection is just ohmic
L and R are parallel. What is their resultant impedance?
ehild
ehild
Will that work?
the unknown resistance is also the part of LR circuit
The impendance is:
[tex]\frac 1 Z = \frac 1 {i\omega L} - \frac {\omega C} {i}[/tex]
Do I have to solve it afterwards with the equation
[tex]R=X+Z[/tex]
And find the X ?
Lindsayyyy said:
The impendance is:
[tex]R=X+Z[/tex]
And find the X ?
That box in the figure is not a capacitor but a resistor R connected parallel to the inductor. And yes, Z+X has to be real.
ehild
Sorry everyone, I'm totally asleep at the switch, having exams in a few days and things are getting confused. I'll try it lateron, have so solve some other things first.
@ Cupid, I don't have any idea why I thought there's a capacity. maybe I should better look at the drawing
thanks everyone
I'm stuck, can't solve it.
I tried to calculate Z, my Z is the parallel connection between R and L
and I get for Z:
[tex]\frac 1 Z = \frac 1 R + \frac {1} {i \omega L}[/tex]
after some conversions I get to:
[tex]Z= \frac {R\omega^{2}L+iR^{2}\omega L} {R^{2}+\omega L^{2}}[/tex]
Now I want to get a pure ohmic resistance so
[tex]Z+X=R[/tex]
but I just can't solve it. The task says the missing component is a "normal" one, so I guess it should be a capacity, inductor etc. Though I tried to take one of these to test if I get a solution, I don't get to an answer. Can anyone help me:confused:
and I get for Z:
Check your algebra. The ω in the term in the denominator should be squared, and the L in the real portion of the numerator should also be squared.
Once you've sorted that out, divide the expression into two parts: the real part and the imaginary part. It's the imaginary part that you want to "take care of" with the new impedance X.
Hope I haven't done any mistakes again:
[tex]X=R- \frac {R\omega^{2}L^{2}} {R^{2}+\omega^{2}L^{2}} - \frac {iR^{2}\omega L} {R^{2}+\omega^{2}L^{2}}[/tex]
so in order to get a pure ohmic term my X has to be:
[tex]X= \frac {iR^{2}\omega L} {R^{2}+\omega^{2}L^{2}}[/tex]
but what component is that? I don't get it :(
If you let Z be the impedance of the parallel R and L components, then you've found that
[tex]Z = \frac {R\omega^{2}L^{2}} {R^{2}+\omega^{2}L^{2}} + i\frac {R^{2}\omega L} {R^{2}+\omega^{2}L^{2}}[/tex]
In order to cancel the imaginary term you need to put in series an impedance that is its negative, that is,
[tex]X = - i\frac {R^{2}\omega L} {R^{2}+\omega^{2}L^{2}}[/tex]
Now, what sort of component has an impedance that yields a negative imaginary term?
I'd say capcity with:
[tex]R_{C}=-\frac i {\omega C}[/tex]
if that answer is right, I still don't understand why to use this one
Yes, a capacitor gives a negative imaginary impedance. :smile:
If you set the above expression for a capacitor's impedance equal to the X expression then you can solve for C, the value that the capacitor must have in order to cancel out the imaginary term of the impedance in Z at a given frequency ω.
