Undergrad Mixed topic : from FEM to analytical solution via limits?
The discussion centers on the feasibility of transitioning from a finite element method (FEM) approach to an analytical solution for wave equations, specifically the Klein-Gordon equation. Participants emphasize the necessity of establishing existence and uniqueness of weak solutions to the partial differential equation (PDE) and the importance of defining limits accurately. Techniques for deriving analytical solutions based on mesh size and polynomial degree of basis functions are mentioned, along with the transformation of coordinates to facilitate the analysis. The conversation highlights the complexities involved in achieving convergence and the challenges of coding the solution.
  • Understanding of finite element methods (FEM)
  • Familiarity with partial differential equations (PDEs)
  • Knowledge of convergence proofs in numerical analysis
  • Basic principles of wave equations and eigenvalue problems
  • Research techniques for proving existence and uniqueness of weak solutions to PDEs
  • Explore methods for deriving analytical solutions from FEM discretizations
  • Learn about coordinate transformations in the context of wave equations
  • Investigate numerical coding practices for implementing FEM solutions
Researchers, mathematicians, and engineers involved in computational physics, particularly those working with finite element analysis and wave equations.
jk22
Is this anyhow possible ?
The system would be a wave equation modelized by a finite elements basis in space and time.
Is there any method to do the limit discretization->continuum with paper and pencil ?
Mathematics news on Phys.org
Do you mean a convergence proof of the approximation method?
Rarely will such a proof give you an explicit, analytical expression for the solution, specially not if the domain has a non-trivial geometry. You will need a precise statement about existence and uniqueness of the (weak) solution to the original PDE, and you will need a precise definition of the limit. (These two requirements are usually not independent of each other.)
There are techniques for computing the analytical solution of your fem discretization. Your analytical solution is then a function of your (constant) mesh size and the polynomial degree of your basis functions. Maybe you can elaborate a bit on what you actually want to achieve.
Likes Delta2
I have never learned well Fem, but I wanted to do spacetime finite elements for the Klein-Gordon equation : ##\frac{\partial^2\psi}{\partial x^2}-\frac{\partial^2\psi}{c^2\partial t^2}=\lambda\psi##.
Then I wanted to make the change of coordinates ##x'=ct-x,y'=x+ct## transforming the LHS in ##4\frac{\partial^2\psi'}{\partial x'\partial y'}=\lambda\psi'## ? if I'm not mistaken
Next step was to choose linear basis functions on squares such that their non zero value lie in ##x',y'\in[0,2ct] ## to respect the limit speed of ##c##. (I think now I should treat this with polar coordinates to be correct)
The usual integration by part to get the stiffness matrix is done and
Strangely it seems to give an eigenvalue problem and the eigenvalue ##\lambda=-\frac{m_0c^2}{\hbar^2}## gives a quantized mass ?
Also there is no initial state to give which seems strange to me.
But I don't know how to code this but rather compute the limit of the steps ##\Delta x'=\Delta y'\rightarrow 0## analytically.
I don't even know if it is a well posed problem nor if it converges.
  • · Replies 36 ·
  • · Replies 42 ·
  • · Replies 22 ·
