Mixing units with functions or derivatives?
Correct usage of units in mathematical functions and derivatives is essential for clarity. In the example of a car that travels 17 miles per gallon, the function m(g) = 17g accurately describes the distance based on gallons of fuel. The derivative dm/dg = 17 miles/gallon is also correct, as it reflects the rate of distance per gallon. It is acceptable to express the equation as m(g) = 17(miles/gallon)*g, as this maintains unit consistency. Properly defining variables with their units ensures that equations are meaningful and clear.
christian0710
Hi,
How do you correctly use units when writing derivatives and functions in math?
Example
A car goes 17miles per gallon, so a function m with the equation m(g)=17g describes the distance it can go with g gallons.
And the derivative dm/dg = 17 miles/gallon. Question: could you write the equation as m(g)=17(miles/gallon)*g or is that incorrect?
christian0710 said:
could you write the equation as m(g)=17(miles/gallon)*g ?
Yes. That would be correct.
christian0710 said:
Hi,
Example
And the derivative dm/dg = 17 miles/gallon.Question: could you write the equation as m(g)=17(miles/gallon)*g or is that incorrect?
Your question is confusing. It looks like you are asking is m(g)=17g correct, if m(g)=17g, except you are writing a label for 17?
When you are defining a variable, you can give it its unit right away or not.
So if you say ##m## is the distance the car can drive, then the variable ##m## has already contained the unit, maybe miles. So you should write:$$m=17mile/gallon\cdot g.$$You can see here my ##g## has also contained its unit: gallon, but 17 not, so then I write 17mile/gallon in the equation.
By the way, we seldom use ##m## to represent the distance because it is more often used to say mass, but it doesn't matter while it just depends on one's habits.
Likes christian0710
It should be evident that if m is a distance, measured in miles, and g is a quantity of gasoline, measured in gallons, then in order that "m (miles)= k g(gallons) make sense, k must be in "miles per gallon" so that (k miles/gallon)(g gallons)= kg miles.
  • · Replies 19 ·
