Model rocket impulse, max height, and time to max height
5 replies · 5K views
robair
can some one just check my work please
model rocket of mass .250 kg is launched vertically with an engine that is ignited at time= 0, the engine provides 20 N.s impulse by firing for 2 sec . upon reaching its maximum height the rocket deploys a parachute and then desends vertically to the ground.
a) find acceleration during the 2sec firing
b) what will be the max height
c) at what time after t=0 will the max height be reached
impulse or change in momentum = F x t ... sumFy = ma = F*engine* - F *gravity* or mg
change in y = v inital x t + 1/2 a t^2
using first equation---> F t = change p ---> F 2 = 20 --> F= 10 N
then second equation F *motor* = ma + mg ---> after you solve for F*motor that is *
10=(.250)a+(.25)(9.81)----> a= 30.19 m/s^2
that was for part A of the question and for part C
i found velocity using p=mv final - mv inital ---> 20= (.25)v -0 since it starts from rest ----> velocity = 80 m/s
then i used the equation Vf^2 = V init ^2 + 2 a change y ----> 6400= 2(30.19) change y , since v init was 0 it cancels ----> and got change in y = 105.995 m
for D
i used the formula: delta y =( velocity init ) ( time) + 1/2 (acceleration ) (time^2) ---> 105.995= 1/2 (30.19) (time^2) since velocity init was 0 that part cancels ----> t= 2.65 s, and it would make sense because its after 2 s
thanks in advance!
Why are you using impulse? This looks to be a straight-forward kinematics question, you should just use your Newtonian kinematics equations:
[tex] y=v_{y0}t+\frac{1}{2}a_yt^2[/tex]
[tex] v_{yf}^2=v_{y0}^2+2a_y(y-y_0)[/tex]
[tex] v_{yf}=v_{y0}+a_yt[/tex]
robair said:
well because in the question it gives you impulse...
Right...seemed to have skipped over that word.
So
[tex] \mathbf{F}_{eng}\Delta t=\Delta p\rightarrow \mathbf{F}_{eng}=10 \mathrm{N}[/tex]
I agree here. But I get
[tex] \sum\mathbf{F}=\mathbf{F}_{eng}-\mathbf{F}_{grav}=m\mathbf{a}\rightarrow \mathbf{a}=\frac{1}{m}\left(\mathbf{F}_{eng}-\mathbf{F}_{grav}\right)=\frac{1}{0.25}\left(10-9.8\right)=0.8 \mathrm{m/s^2}[/tex]
well i actually asked my physics teacher and he said i got A right so acceleration is 30.2 but i got B and C wrong... he gave me the right answers for B (246m) and C (8.15s) so the thing right now is to figure out what i did wrong in B and C
Hmm...I get different answers than your teacher, particularly on the time part.
This is how I went about solving it:
The height of the rocket immediately after the engine burns out is given by
[tex] y_b=at^2=(30.2)(2)^2=120.8\,\mathrm{m}[/tex]
The velocity at this point is given by
[tex] v_b=v_0+at=0+30.2\cdot2=60.4\,\mathrm{m/s}[/tex]
So at the end of the engine burn, the rocket has total energy
[tex] E=K+U=\frac{1}{2}mv_b^2+mgy_b=752\,\mathrm{J}[/tex]
At the maximum height, the particle has zero velocity but through the conservation of energy, it has the same energy:
[tex] E=U=mgy_{max}=752\rightarrow y_{max}=307\,\mathrm{m}[/tex]
The total time of this is then given by
[tex] y_{max}=at^2\rightarrow t=\sqrt{\frac{y_{max}}{a}}= \sqrt{\frac{307}{30.2}}=3.2\,\mathrm{s}[/tex]
Even using your teacher's result of 246 m for [itex]y_{max}[/itex] gives me a value of 2.85 s; however if you forget to take the square root of this number, you do get 8.15 (that is, if you say [tex]t=y_{max}/a=246/30.2=8.15[/itex], but this is not correct).[/tex]
