Modern Cosmology by Dodelson: Problem 6.12 a
travelingscienceman
The general goal of the problem is to derive some useful identities involving the slow-roll parameters during inflation.
For part a show that:
$$\frac {d} {d\eta} (\frac {1} {aH})= \epsilon - 1$$
$$\epsilon \equiv \frac {d} {dt} (\frac {1} {H})= \frac {-\dot H} {aH^2}$$
$$H=\frac {\dot a}{a}$$
$$\eta\approx\frac{-1}{aH}$$
First I put everything into the scale factor a and its derivatives:
$$-\dot H = \frac{\dot a^2 - \ddot a a}{a^2}$$
$$\frac{1}{a H^2}=\frac{a}{\dot a^2}$$
$$\frac {-\dot H} {aH^2} = \frac{\dot a^2 - \ddot a a}{a\dot a^2}=\frac{1}{a}-\frac{\ddot a}{\dot a^2}=\epsilon$$
Now this is where I am struggling.
He uses a derivative with respect to time and one with respect to conformal time (##\eta##). Coupled with the fact that
$$\frac {d} {d\eta} (\frac {1} {aH})=\frac {d} {d\eta} (-\eta) =-1=\epsilon - 1$$
Which means that ##\epsilon=0## which is not correct. Instead of substituting I could do the following:
$$\frac {d} {d\eta} (\frac {1} {aH})=\frac {d} {d\eta} (\frac {1} {\dot a})=\frac {-1} {\ddot a}=\epsilon - 1$$
Rearranging we get
$$\epsilon=1-\frac {1} {\ddot a}$$
And I am not sure this is correct either. I cannot see any way to make the RHS equal to epsilon.
Any help showing where I might have gone wrong would be appreciated and thanks in advance for taking a look at this!
Try using that ##\frac {d} {d\eta} = a \frac{d}{dt}##. So you've got ##a \frac{d}{dt} (\frac{1}{a} \frac{1}{H})##. It's pretty straightforward from there.
That helps but I am still having trouble. With ##\epsilon=\frac{-\dot H}{a H^2}## I just end up going in circles. But if I work with ##\epsilon=\frac{d}{dt}\frac{1}{H}## I get the following:
$$\epsilon=\frac{d}{dt}\frac{1}{H}=\frac{\dot a^2 - \ddot a a}{\dot a^2}$$
$$\frac{d}{d\eta}\frac{1}{\dot a}=a\frac{d}{dt}\frac{1}{\dot a}=\frac{-a}{\ddot a}=\epsilon-1$$
$$1+\frac{a}{\ddot a}=\epsilon=\frac{\dot a^2 - \ddot a a}{\dot a^2}$$
$$\dot a^2 \ddot a -a \dot a^2=\ddot a \dot a^2 - \ddot a^2 a$$
$$\dot a =\ddot a$$
Which is better but not right.
From looking inside Dodelson's text at Amazon, it appears that the author uses a dot to denote differentiation with respect to ##\eta##. But, it looks like you are sometimes interpreting the dot as differentiation with respect to ##t## (for example, when you write ##H =\large \frac{\dot a}{a}##).
Ah, that explains some inconsistencies. I assumed dot was differentiation by ##t## from that definition of ##H##.
Thank you both. Today with a clear head I figured it out.
$$H=\frac{\dot a}{a^2}$$
And so
$$\epsilon=\frac{2\dot a^2 -\ddot a a}{\dot a^2}$$
Which made things much easier.
