Mohrs Circle, Von Mises and Minimum Yield Strength Help
The discussion revolves around the calculation of minimum yield strength using Mohr's Circle and the von Mises criterion in the context of material mechanics. Participants explore the relationship between stress states and yield strength, comparing different theories for estimating yield strength.
  • One participant expresses confusion about calculating minimum yield strength, having used Mohr's Circle and the von Mises equation to arrive at a value of 636.8 MPa, while the textbook states 660.4 MPa.
  • Another participant asks for the initial stress values used in the calculations, specifically sigma-x, sigma-y, and tau-xy.
  • The initial stress values provided are sigma-x = 560 MPa, sigma-y = 0 MPa, and tau-xy = 175 MPa.
  • One participant agrees with the figures for Mohr's Circle and suggests an alternative formula for von Mises when sigma-y = 0, indicating that Mohr's Circle may not be necessary in this case.
  • A participant raises a potential mix-up between the Tresca and von Mises criteria, providing the formula for Tresca and suggesting it could lead to the textbook's yield strength value of 660.4 MPa.
  • A later reply acknowledges the mix-up regarding the theories and clarifies the distinction between maximum shear stress theory and maximum distortion energy theory.
  • Another participant explains that the Tresca method estimates a higher maximum stress compared to the von Mises theory, leading to a discussion about the implications of this difference in terms of conservativeness and failure envelopes.
Participants generally agree on the calculations and the formulas involved, but there is a discussion about the differences between the Tresca and von Mises criteria, indicating that multiple views on the interpretation of these theories remain.
The discussion highlights potential confusion regarding the application of different yield criteria and the specific conditions under which they are used, but does not resolve these nuances.
Mairi
Hi
Wasn't sure where to post this, hope it's ok in here!
I've gotten myself very confused as to how to find the minimum yield strength for an element. I have used Mohrs circle to find sigma1 and sigma2, then plugged that into the von mises equation to find sigma-von = 636.8MPa. The textbook gives me the answer of minimum yield strength of 660.4MPa, but how do I get to that? I've checked and double checked my sigma1 and 2 answers (610.2 and -50.2)and I think they are correct. Not sure where to go from here and neither lecture slides nor textbook are helping much!
Thanks!
Hello mairi, welcome to Physics Forums.
What values of sigma-x and sigma-y (and tau if they exist) did you start with?
Woops might have been an idea to state that in the first place! Sigma-x was 560MPa, sigma-y 0MPa and tau-xy was 175MPa.
Well I agree with your figures for both the Mohr circle and by direct calculation.
Incidentally you do not need a Mohr circle for the stress state indicated.
If σy = 0 then Von Mises can be written
[tex]Y = \sqrt {\sigma _x^2 + 3\tau _{xy}^2}[/tex]
as an alternative to the formula using σ1 and σ2
So I would be interested if you have a reference or could post more of this book.
Are you sure you haven;t got the Tresca and Von Mises ctiteria mixed up?
The formula for the Tresca max stress is
[tex]Y = \sqrt {\sigma _x^2 + 4\tau _{xy}^2}[/tex]
or the max difference of principel stresses.
Either way that works out to the 660.4 MPa in your book.
:blushing: You're absolutely right, I didn't register that the question was asking me for the max-shear-stress theory not max-distortion energy! Silly mistake!
But thank you :D
They are actually both shear stress theories, but offer different estimates of the maximum shear stress encountered, given a particular state of stress at some point.
The Tresca method estimates the actual max stress as being (slightly) higher than does the Von Mises theory.
Are you comfortable with how this leads to the the conclusion that Tresca is more conservative or that the failure envelope is smaller?
Yes that makes sense. Thank you!
88K
27K
11K
