Moment of Inertia of an Ellipsoid
The discussion revolves around the calculation of the moment of inertia for an ellipsoid, with a specific focus on identifying a potential error in the factor used in the formula. The original poster expresses uncertainty about their answer and seeks assistance in pinpointing the mistake.
  • Assumption checking, Problem interpretation, Exploratory
  • Participants discuss the original poster's confusion regarding the factor in the moment of inertia formula, with some questioning the method of presenting equations. There is an exploration of how to effectively share mathematical expressions in the forum.
Some guidance has been offered regarding the proper format for posting equations, which may help facilitate clearer communication. The discussion is ongoing, with participants exploring different aspects of the problem and sharing tips on formatting.
There is a mention of a word document containing the original poster's work, which may limit accessibility for others wishing to assist. The original poster also indicates difficulty in using the forum's equation formatting tools.
metgt4
I seem to be off by a factor of 2 on the answer to this problem but I can't find where I went wrong. The term in front should be 1/5 and not 2/5. Does anybody see the mistake in my work? It is attached in a word document because I can't figure out how to put the equations into this post otherwise.
Thanks!
Andrew
Just to let you know, many people, myself included, that might otherwise have a look at your stuff won't bother to open a word document. It is as easy to put your equations here as in a word document in the first place.
I tried to put the equations in my post but it didn't seem to work. Is there any special way to put equations into a post that I'm not seeing?
You put the equations in LaTeX format surrounded by tex tags. You can learn just by looking at other's posts. For example just to give you some ideas, click on this:
[tex]H(x)=\int_{0}^{\frac{\pi}{2}} \frac {f^2(x)}{g(x,\theta)} d\theta[/tex]
Thanks! That helped a lot
