Moment of Inertia on Semi-Hollow Cylinder
The moment of inertia for a semi-hollow cylinder can be derived using integration, resulting in the formula I = (1/2)m(r22 + r12). The derivation involves calculating the area and mass density, where dm = σ dA and A = π(r22 - r12). The integration bounds are set from r1 to r2, leading to the conclusion that the moment of inertia is dependent on the outer and inner radii of the cylinder.
  • Understanding of moment of inertia concepts
  • Familiarity with integration techniques
  • Knowledge of mass density (σ) and area calculations
  • Basic algebraic manipulation, including factoring
  • Study the derivation of moment of inertia for different geometric shapes
  • Learn about the application of integration in physics problems
  • Explore advanced integration techniques relevant to physics
  • Investigate the implications of mass distribution on moment of inertia
Students studying physics, particularly those focusing on mechanics, as well as educators and professionals involved in engineering and design applications requiring an understanding of rotational dynamics.
trautlein
A hollow cylinder has mass m, and outside radius r_{2}, and an inside radius r_{1}. Use intergration to show that the moment of inertia about its axis is give by I=\frac{1}{2}m(r^2_2+r_1^2).
Uniform composition is assumed.
I=\int r^2dm
dm=\sigma dA
and
A=\pi r^2
(note, later on I constrict the lower and upper bounds of integration to account for the now entire area of the circular side, which sounds as though it is assumed here)
Note: Using equations above.
I=\int r^2dm
I=\int r^2\sigma dA
dA=2\pi rdr
I=\sigma 2\pi\int r^3dr
(here I insert my upper and lower bounds)
I=\sigma 2\pi\int_{r_1}^{r_2} r^3dr
I=\sigma 2\pi \left(\frac{r^4_2}{4}-\frac{r^4_1}{4} \right )
I=\sigma \pi \left(\frac{r^4_2}{2}-\frac{r^4_1}{2} \right )
I=\frac {1}{2}\sigma \pi \left(r^4_2-r^4_1 \right )
\sigma=\frac{m}{A}
and since
A=\pi r^2_1-\pi r^2_2
then
I=\frac{m}{2(\pi r^2_1-\pi r^2_2)} \pi \left(r^4_2-r^4_1 \right )I=\frac{\left(r^4_2-r^4_1 \right )m}{2 (r^2_1-r^2_2)}This is as far as I venture into the problem before I realize that I've done something wrong if I'm supposed to get the answer they assume at the beginning of the problem. Where did I go wrong?
Thank you very much for the help, it's greatly appreciated.
That is correct so far. Remember a2-b2=(a+b)(a-b). So if you factorize the numerator what do you get?
Given:
Then:
I=\frac{1}{2}m(r^2_1+r^2_2)
Great! Thank you so much! I actually forgot how those exponents would go into each other, that was my issue. Thanks for leading me toward the right answer there!
  • · Replies 17 ·
