Moment of Inertia using Triple Integral
To compute the moment of inertia around the z-axis for the solid unit box [0,1]x[0,1]x[0,1] with a density of δ = x² + y² + z², the relevant formula is I = ∫∫∫ r² δ dV, where r² is defined as x² + y². The integration bounds for each variable are straightforward, ranging from 0 to 1 for x, y, and z. The suggested setup for the integral is ∫₀¹ ∫₀¹ ∫₀¹ (x² + y²)(x² + y² + z²) dz dy dx. The order of integration does not affect the outcome due to the independence of the boundaries.
jj2443
Compute the moment of inertia around the z-axis of the solid unit box [0,1]x[0,1]x[0,1] with density given by \delta=x^{2}+y^{2}+z^{2}.
I=\int\int\intr^{2} \delta dV
I know that the distance r^{2} from the z-axis would be x^{2}+y^{2}. I don't know how to determine the bounds and the order of the three integrals. Could someone please explain to me how to determine which order I should integrate, and then how I go about finding the bounds of integration for each of the three integrals.
Thanks!
Since none of the boundaries on your volume is dependent on each other you can just write it as a simple 'volume' integral if you want to think of it that way, as if you're finding the volume of the cube but with the other terms involved: r^{2} and {\delta}
So in my mind it should be set up as follows:
\int_{0}^{1}\int_{0}^{1}\int_{0}^{1}(x^{2}+y^{2})(x^{2}+y^{2}+z^{2})dzdydx
The order of integration won't matter.
Oh, that's much easier than I was trying to make it. Thank you!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
