Moment of inertia with triple integrals
The discussion focuses on calculating the moment of inertia of a solid cone using triple integrals, specifically comparing cylindrical and spherical coordinate systems. The correct integral setup for cylindrical coordinates is established as ∫∫∫ r² dV with limits r (0 to z/a), θ (0 to 2π), and z (0 to b), yielding the moment of inertia I = (πb⁵)/(10a⁴). The spherical coordinate approach is deemed less effective due to the complexity of limits and the need to adjust the integrand to account for the perpendicular distance from the axis of rotation.
  • Understanding of triple integrals in calculus
  • Familiarity with cylindrical and spherical coordinate systems
  • Knowledge of the moment of inertia concept in physics
  • Ability to perform multivariable integration
  • Learn about the derivation of the moment of inertia for various geometric shapes
  • Study the differences between cylindrical and spherical coordinates in integration
  • Explore advanced integration techniques for multivariable calculus
  • Investigate the application of triple integrals in physics problems
Students and professionals in physics and engineering, particularly those focusing on mechanics and calculus, will benefit from this discussion on calculating moments of inertia using integration techniques.
demonelite123
so i have to find the moment of inertia of a solid cone given by the equations z = ar and z = b by using a triple integral. The density of the cone is assumed to be 1. so the integral looks like ∫ ∫ ∫ r^2 dV. so first i did it with dV = rdrdθdz with limits r (from 0 to z/a), θ (from 0 to 2pi), and z (from 0 to b) and i got the answer (pi)b^5 / (10a^4) which seems to be right. now i am trying to do the triple integral instead with dV = rdzdrdθ. i am having trouble deciding the limits now. for z, i know that r and θ are to be kept constant so my limits for z are from ar to b. then my limits for r are from 0 to z/a and my limits for θ are from 0 to 2pi. however after doing the integrations, my answer turned out messy involving a's, b's, and z's which shouldn't be in the final answer. how do i set up the limits correctly when integrating with respect to z first, then r and theta afterwards?
Ok, your first try r:0~z/a, θ:0~2pi, z:0~b. And first integrate r then z(or last).
why z:0~b, not z:ar~b?
The reason is we first integrate r, and r:0~z/a, or not?
Now, your secend try z:ar~b, θ:0~2pi, and r:0~z/a.
We first integrate z, why r:0~z/a appears z again?
z/a isn't a constant.
Woah, you call this an introductory physics problem??
OK, so I don't know the equation for the moment of inertia of a cone off the top of my head. But if you do your math right, then your answer from the cylindrical coordinates integral will be right, but your answer from the spherical coordinates integral will be wrong. You've got this funny equation in physics which says,
I = \int r^2dm
But what they don't tell you is that the "r" is the perpendicular distance from the axis of rotation (which you usually set to be the z axis). If you do it in spherical coordinates, you can't just assume that the r in the above integrand is the same as the r from spherical coordinates. Instead, you need to use:
I = \int [rsin(\theta)]r^2sin(\theta)drd\theta d\phi
Multiplying r by sin(\theta) will take the component of \vec{r} in the xy plane, which is what you want.
As for the limits of integration to use in spherical coordinates...I'm going to have to think about that one for a second. Spherical coordinates are a very unnatural way to describe a cone.
To 3#
For this problem used cylindrical coordinate maybe better.
oh i got it now. the limits on r should be from 0 to b/a. setting that limit gave me the same answer as i got before. thanks for the help everyone! :smile:
  • · Replies 28 ·
