Engineering Understanding Moment Connections in Structural Design
The discussion centers on moment connections in structural design, emphasizing the necessity for end plates to resist bending moments transferred from beams to columns. Participants confirm that any bending moment on the beam directly impacts the column, reinforcing the importance of proper design in moment connections. This understanding is crucial for ensuring structural integrity in construction projects.
  • Understanding of structural engineering principles
  • Familiarity with moment connections in steel structures
  • Knowledge of beam-column interactions
  • Basic concepts of load transfer in structural design
  • Research design specifications for moment connections in steel structures
  • Explore software tools for structural analysis, such as SAP2000 or ETABS
  • Learn about the effects of bending moments on structural stability
  • Study case studies on failures due to inadequate moment connections
Structural engineers, architects, and construction professionals involved in the design and analysis of steel structures, particularly those focusing on moment connections and load transfer mechanisms.
dccd
Hi, anyone know whether full depth end plate between beam web and column is moment or simple connection ? In https://www.steelconstruction.info/Moment_resisting_connections#Welded_beam-to-column_connections and SCI P398, it's considered as moment connection, In SCI P358 and https://www.steelconstruction.info/Simple_connections#Flexible_end_plate_connections, it's considered as simple connection.
Not available
I Think it's moment connection. Because the end plate must be able to resist the moment transferred from the beam to the column. Please correct me if I am wrong.
I believe that you are correct.
Any bending moment on the beam will be transferred to the column.
Welcome! :cool:
Likes dccd
  • · Replies 0 ·
