Momentum factor into the force applied to an object at rest
Momentum plays a crucial role in determining the outcome of a collision between a moving object and an object at rest, as momentum is conserved and influences final speeds. The force experienced during the collision is affected by the duration of the interaction; longer collisions result in lower acceleration and consequently lower force. In scenarios involving the breaking of a human bone, the energy involved is more significant than momentum, with impact toughness being a key factor in determining the force required to break the bone. The relationship between force and momentum is expressed by the equation F = dp/dt, indicating that force equals the change in momentum over time. Understanding these principles is essential for analyzing collisions and material strength in engineering contexts.
cscott
How does momentum factor into the force applied to an object at rest hit by another which is moving?
Assuming no external forces, momentum is conserved so the initial momentum of the moving object relates to that (as well as how elastic the collision is)- it determines the final speeds. However, the "force" involved in the collision will also depend upon how long the interaction takes. In order go from rest to whatever final speed the object has, it must accelerate during the collision. The longer the collision takes, the lower the acceleration and so the lower the force required.
Lets say I have a human bone, and I'm putting weights on it until it snaps, then I have another bone but let the weights fall onto the bone. I'm assuming the second bone will break with less weight because we're letting the weights fall. It is momentum that's involved here? What equations would I be working with?
No, its energy. There is an engineering test called a http://www2.umist.ac.uk/material/research/intmic/features/charpy/notes.htm that takes into account all the factors that Halls mentioned and calls the energy required to break a sample "impact toughness". By using a heavy pendulum to break a test sample, the energy required to break it can be measured simply by using the difference in the height of the pendulum between the upstroke and the downstroke and applying the potential energy equation.
The OP first question asked about the relationship between force and momentum, That relationship is:
F = dp/dt where Force equals the change in momentum divided by the change in
time (during the collision)
This relationship is not evident in the arm breaking scenario but is best seen with an example such as a tennis player serving a ball or a golfer tee-ing off. The tricky part is in measuring the time of impact. Also, the force may not be constant during the collision, hence the need for differential calculus.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
