Calculating Work for Monatomic Gas Expansion
The discussion focuses on calculating the work done by a monatomic gas during expansion from an initial volume \( V_i = V_0 \) to a final volume \( V_f = 3V_0 \) using the pressure relationship \( p = P_0[1 - 0.9\sin\left(\frac{\pi(V - V_0)}{4V_0}\right)] \). The work done is computed using the integral \( W = \int_{V_0}^{3V_0} P \, dv \), where \( P \) is substituted with the given pressure function. Additionally, the net heat flow \( Q \) is determined using the equation \( Q = nRT \ln\left(\frac{V_2}{V_1}\right) \), leading to the conclusion that heat flows into the gas during the expansion, as indicated by the positive value of \( Q \).
  • Understanding of thermodynamic principles, specifically the ideal gas law (PV = nRT).
  • Familiarity with calculus, particularly integration techniques for evaluating work done by a gas.
  • Knowledge of heat transfer concepts in thermodynamics, including isothermal processes.
  • Ability to interpret mathematical relationships and functions in physical contexts.
  • Study the derivation of work done in non-constant pressure scenarios using calculus.
  • Learn about isothermal and adiabatic processes in thermodynamics.
  • Explore the implications of heat flow in different thermodynamic cycles.
  • Investigate the behavior of monatomic gases under varying conditions and their equations of state.
Students and professionals in physics and engineering, particularly those focusing on thermodynamics, gas laws, and heat transfer principles.
scholio
one mole of a monatomic gas expands from V_i = V_0 to V_f = 3V_0 according to the relationship:
p = P_0[1 - 0.9sin( (pi(V - V_0))/4V_0 )]
a) compute the work done by the gas as it expands from V_i = V_0 to V_f = 3V_0
b) compute the net heat flow during this expansion
c) does heat flow into or out of the gas during this expansion?
PV = nRT where P is pressure, V is volume, n is moles, R = 8.314 constant, T is temperature
Q = W = nRT ln (V_2/V_1) where W is work, Q is heat, V_2 and V_1 is volume
not sure what else
I haven't got far because i don't understand the given relationship, what is the difference between the capital and lowercase p, is the lowercase p stand for momentum? i doubt it..
i used the second eq and tried to solve for work but didn't know how to implement the relationship given, where does it come into play?
any help appreciated...
not sure what else
Ignore lowercase. p is just the pressure P.
Start with the definition of work:
W = \int_{V_0}^{3V_0} Pdv
Substitute for P:
W = \int_{V_0}^{3V_0} P_0(1 - \sin(\pi(V - V_0)/4V_0 )dv
AM
thanks AM, so does it become:
W = P_0[1 - 0.9sin( (pi(V - V_0))/4V_0 )](3V_0) - P_0[1 - 0.9sin( (pi(V - V_0))/4V_0 )](V_0) ?
how does the V and the V_0 come into play within the given function?
cheers
cheers
sorry double posting, 'edit' option wasn't available for some reason.
part b asks to determine the heat flow during the expansion, am i correct to assume that the pressure changes as does the volume, thus the expansion is isothermic
and should use eq Q_isotherm = W = nRT ln (V_2/V_1) where n = 1 mole, R = constant 8.314, T is not specified in problem, assumed constant and V_2 = 3V_0, V_1 = V_0
plugging in those values, for Q (heat) i got Q = 9.13T where T is the temp, constant
part c, asks if heat flows into or out of the gas during the expansion --> i said, since Q = 9.13T is positive, it means heat is flowing into the gas
correct??
cheers
You just have to figure out the integral:
which is of the form:
W = \int_{V_0}^{3V_0} P_0dv - \int_{V_0}^{3V_0} P_0\sin(kV - \phi) dv
Work that out. Remember P_0 and V_0 are constants.
AM
