Calculating Distance and Time for One-Dimensional Motion in Physics
  • Thread starter Thread starter hquang001
    Dimension Motion
This discussion focuses on calculating distance and time for one-dimensional motion in physics, specifically using the SUVAT equations. The total time for the motion is 36 minutes, broken down into segments with varying acceleration. The maximum speed (Vmax) is calculated as 300 km/h, and the total distance covered is confirmed to be 60 km after recalculating with the correct parameters. The importance of using a speed vs. time graph to visualize the motion is emphasized, as it helps clarify the relationship between speed, time, and distance.
  • Understanding of SUVAT equations in physics
  • Basic knowledge of kinematics and motion
  • Ability to interpret speed vs. time graphs
  • Familiarity with acceleration calculations
  • Learn how to derive and apply the SUVAT equations in various motion scenarios
  • Study the principles of kinematics in one-dimensional motion
  • Explore graphical methods for analyzing motion, specifically speed vs. time graphs
  • Investigate methods for verifying calculations in physics problems
Students studying physics, educators teaching kinematics, and anyone interested in understanding one-dimensional motion and its calculations.
hquang001
A train which connects city A to C, leaves the station A at 10:06 AM. The train accelerates for 6 minutes with a constant rate before it reaches its top speed. Then it is travelling with constant speed. Then it reduces its speed with a constant rate of 600 km/h² before it reaches the station of city C (The value of the speed is 0km/h when it reaches the station C). The train should arrive at city C at 10:42 AM. The distance between A to C is 60km
a) What is the acceleration of the train in the beginning ?
b) What is the maximum speed of the train ?
X = Xo + Vot + 1/2 at²
V = Vo + at
V² - Vo² = 2aX
total time: t = 36 mins = 0.6h = t1 + t2
=> t2 = t - t1 = 0.6h - 0.1h = 0.5h
Vmax = a1 x t1
Vat C = Vmax + a2t2
substitute Vmax in Vat C we have : 0 = a1 x 0.1h + (-600 km/h²) x 0.5h => a1 = 3000km/h²
Vmax = a1 x t1 = 3000 x 0.1 = 300km/h
I check the result by:
x1 = ½ a1 t1² = ½ . (3000). (0.1²) = 15km
x = ½ a2t2² + vmaxt2 + x1 = ½ (-600).(0.5²) + (300).(0.5) + 15km = 90km
I don't know why the total distance when i check the result turn out to be 90km, while the questions states that AC is 60km
hquang001 said:
(-600 km/h²) x 0.5h
It is not slowing down for half an hour. It spends some unstated time at constant speed.
@hquang001 If I were you, I'd draw a speed vs time graph, where the distance is the area under the graph. It's easy to get lost if you only use the SUVAT equations.
This is the hint which i forgot to put in the question statement: It could be that you get more than one answer .
After considering your help and calculating again, i really got two possible maximum speed value like the hint stated 154751291_758301718455564_3019073286399381927_n.jpg
I want to ask how i can check if my results are correct in situation like this, or in general, one dimensional motion ?
Thank you for your help!
I have done it again and also include a simple graph
After considering your help and calculating again, i really got two possible maximum speed value like the hint stated View attachment 278640
Have you checked your solutions? Do they both work out?
Only one solution is possible
When i substitute V = 522.09 km/h to find t3,
t3 = 0.87h which will make t2 negative
Okay, so you have one good solution?
Yes, Vmax = 137.91 is possible
but i don't know if it's correct or not, i don't know how to check it
You have to calculate the other quantities: initial acceleration; ##t_3##, ##t_2## and check you get the right time and distance for the journey. Tricky question!
Yes i have calculated all the quantities you mentioned, and find each distance x1,x2,x3 which add up 60km. So i think this should be correct. Thank you very much for your help
  • · Replies 75 ·
17K
