Can a rider change the combined center of gravity of a motorcycle by leaning?
The discussion centers on the influence of a motorcycle rider's weight on the combined center of gravity (COG) of the motorcycle system. In a closed system, the rider cannot alter the COG by shifting weight; however, in an open system with tires on a road, the rider can influence the COG through body inertia. The interaction between the bike's effective angular inertia and the gyroscopic reactions in the wheels plays a crucial role in resisting changes in lean angle. Additionally, the steering dynamics, where the front tire's contact point is behind the pivot axis, contribute to the rider's ability to initiate lean through counter steering.
  • Understanding of motorcycle dynamics and physics
  • Knowledge of gyroscopic effects in rotating systems
  • Familiarity with the concept of center of gravity in mechanical systems
  • Basic principles of friction and contact forces
  • Research the principles of motorcycle dynamics and lean angle mechanics
  • Study gyroscopic effects and their impact on vehicle stability
  • Explore the concept of counter steering in motorcycle handling
  • Investigate the role of friction in vehicle dynamics and cornering
Motorcycle enthusiasts, physics students, motorcycle instructors, and anyone interested in understanding motorcycle handling and dynamics.
Erunanethiell
In a closed system, I know the rider wouldn't be able to change the combined center of gravity of the system by moving his weight around. If he pushes the bike to lean to the right, he would go to the left by the amount that would keep the combined cog the same.
But a bike with tires and a road under it is not a closed system, the tires wouldn't let the lower part of the bike left or right when tryingo to initiate lean. Does this mean it is possible to push with your bodies inertia to the bike, and the combined cog will be changed? I thing if you do so above the cog of the bike, you could, but I am not sure.
It is a bit like a swing set where you can start swinging without touching the ground - just as inverted pendulum, with the support below the bike instead of above the swing.
Why does it work if it wouldn't work in a closed system? Is it because tires stop the lower part of the bike move laterally?
Right. Friction (and the non-zero contact width) can lead to a net force and torque on the system.
In the case of a swing, the supporting chains or ropes are displaced forwards or backwards by the person leaning forwards or backwards, pushing forward or pulling backwards on the supporting chains or ropes, resulting in a backwards or forwards component of tension in the supporting chains or ropes, and this initiates movement.
But a bike with tires and a road under it is not a closed system, the tires wouldn't let the lower part of the bike left or right when trying to initiate lean. Does this mean it is possible to push with your bodies inertia to the bike, and the combined cog will be changed? I thing if you do so above the cog of the bike, you could, but I am not sure.
The bikes effective angular inertia, which is affected by the gyroscopic reactions in the wheels, resists a change in lean angle due to the rider leaning to one side or the other. The result is some of that force is applied to the pavement, coexistent with the pavement applying a force onto the bike in the same direction as the rider leans.
The dominant effect is related to steering. On a typical bike, the point of contact of the front tire is "behind" the pivot axis, so if the rider leans to the left, the front tier initially steers to the right, an indirect form of counter steering.
  • · Replies 35 ·
  • · Replies 86 ·
15K
  • · Replies 44 ·
  • · Replies 65 ·
9K
14K
