What is the Tension in Block m2's String in a Pulley System?
The tension in the string attached to block m2 in a pulley system is determined to be 2T, where T is the tension in the string attached to block m1. This conclusion arises from analyzing the forces acting on the blocks and the idealized assumption of a massless pulley. The force balance equations for both blocks, along with the conservation of string principle, lead to the result that the upward force on block m2 is effectively doubled due to the two strings exerting tension. The discussion emphasizes the importance of recognizing the ideal conditions of the pulley system in deriving this relationship.
  • Understanding of Newton's laws of motion
  • Familiarity with force balance equations
  • Knowledge of pulley systems and tension in strings
  • Concept of idealized objects in physics (e.g., massless pulleys)
  • Study the principles of Newton's second law in detail
  • Learn about the dynamics of pulley systems and their applications
  • Explore the concept of ideal vs. real pulleys in mechanical systems
  • Investigate the effects of mass on tension in non-ideal pulley systems
Students studying physics, particularly those focusing on mechanics, engineers designing pulley systems, and educators teaching concepts of tension and force balance in idealized scenarios.
tzonehunter
The diagram shows a system of two blocks suspended by ideal strings and pulleys.
If the tension of the string attached to block m1 is T, what is the tension of the string attached to block m2?
Due to conservation of string, a1/2 = a2
Force balance on mass 1:
∑F1 = m1a1 = m1g - T
Force balance on mass 2:
∑F2 = m2a2 = m2g - T2
Substituting a1/2 = a2 into the ∑F2 expression, I get
a1 = 2g - 2T2/m2
Substituting the above into the ∑F1 expression, I get
T2 = m2g/2 + m2T/(2m1)
The correct answer is given as 2T. I'm struggling with this, because I don't see how the pulley could accelerate upwards if this is true, as all forces are balanced.
The tension in the string is same since the string is assumed massless .It doesn't depend on the acceleration of the blocks .Since two strings are pulling block 2 upwards the upwards force on block 2 is 2T.
It may also be useful to note the tension across a frictionless pulley is uniform. So if you knew the tension on the left was ##T##, the tension in the two other strings is also ##T##. Since there is two of them, it is ##2T##.
tzonehunter said:
T
That is true for the magnitude of the accelerations. But they are of opposite directions. If m1 moves downward, m2 moves upward.
So you chose m1 moving downward.
You have to change the sign of the right-hand side as m2 accelerates upward: m2a2 = T2-m2g
The tensions also act on the moving pulley, 2T upward and T2 downward. But the pulley is massless, so ma =0. The net force on the pulley must be zero.
ehild
Thank you to those that replied. I thought about this over night... I think I'm getting caught up in the idea that the pulley is a real object, but in the problem we're asked to assume an "ideal pulley".
How does this explanation sound:
The moveable pulley (subscript P) must have the same acceleration as m2. The acceleration of the moveable pulley is:
aP = FNet,P / mP = a2
FNet,P = 2T - T2
As long as m1 and m2 are constant, then a2 is constant and aP is constant.
An ideal pulley is massless, so as mP --> 0 , FNet,P --> 0. The lighter the pulley, the smaller the difference between 2T and T2. Less net force is required to produce the same acceleration of a less massive object.
This leaves us with
T2 --> 2T for the idealized case where mP --> 0.
FNet,P = 2T - T2
As long as m1 and m2 are constant, then a2 is constant and aP is constant. Indeed, if the pulley had non-negligible mass then you could not take the two upward tension forces as equal.
This leaves us with
Yes. More generally, if an object is taken as massless then you can assume there's no net force on it (or its acceleration would be infinite). Similarly torques.
  • · Replies 34 ·
  • · Replies 17 ·
  • · Replies 22 ·
