Why Does a Moving Rod Appear Inclined in Different Reference Frames?
The discussion focuses on the apparent inclination of a moving rod in different reference frames, specifically using Lorentz transformations. The coordinates of the rod's tips in frame S' are defined as C₀ = (t', 0, ut', 0) and C₁ = (t', L, ut', 0). The angle φ is derived using the relationship tan(φ) = Δx/Δy, with Δx calculated as γL. The challenge lies in determining Δy, as the calculations suggest that Δy equals zero, indicating a misunderstanding of the rod's orientation in the reference frames.
  • Understanding of Lorentz transformations
  • Familiarity with the concept of reference frames in physics
  • Knowledge of trigonometric relationships in coordinate systems
  • Basic grasp of relativistic velocity composition
  • Study the application of Lorentz transformations in different reference frames
  • Learn about relativistic velocity addition formulas
  • Explore the implications of time dilation and length contraction
  • Investigate the geometric interpretation of angles in relativistic contexts
Students and professionals in physics, particularly those studying special relativity, as well as educators looking to clarify concepts related to reference frames and motion.
Data Base Erased
A ##S'## frame moves with velocity ##v\hat{e_{x}}## with respect to a S frame.
There's a rod with length ##L##, parallel to the ##x'## axis moving with velocity ##u \hat{e_{y'}}##.
Show that the rod seems inclined and what's the inclination angle?
##t = \gamma (t' + vx')##
##x = \gamma(x' + vt')##
##t' = \gamma (t - vx)##
##x' = \gamma(x - vt)##
Ateempt of solution:
There are two key coordinates in this scenario, the leftmost tip of the rod, which in ##S'## is ##C_{0} = (t', 0, ut',0)## and the opposite tip
##C_{1} = (t', L,ut',0)##
An angle ##\phi## could be found through a relationship such as ##tan(\phi) = \frac{ \Delta x}{ \Delta y} ##
For ##\Delta x## I have
## x_{0} = \gamma ( x_{0'} + vt') = \gamma vt'## and
##x_{1} = \gamma (x_{1'} + vt') = \gamma (L + vt')##.
##\Delta x = \gamma (L + vt' - vt') = \gamma L##
For ##\Delta y## I'm not sure how to calculate its coordinates in ##S##. Should I use the velocity composition formula? The lorentz transformations would be trivially applied then?
Edit:
I tried to deduce a composition for this case in the following manner
In ##S'##, ##u_{s'} = \frac {\Delta y'}{\Delta t'} ##
I can write these for ##S## to find ##\frac{\Delta y}{\Delta t}##
##u_{s'} = \frac {\Delta y}{\gamma (\Delta t - v \Delta x)} ## and dividing by ##\Delta t##
##u_{s'} = \frac{ u_{s}}{\gamma (1 - v u_{s})}##
Solving for ##u_{s}## I get ##u_{s} = \frac{ u_{s'} \gamma}{1+ \gamma u_{s'} v}##
So to find the ##y## coordinates do I use
##y = \gamma_{u_{s}} (y' + u_{s} t')##
but this is wrong because all these parameters are the same for both ##C_{0'}## and ##C_{1'}##, what would imply ##y_{0} = y_{1}## hence ##\Delta y = 0##
The rod is parallel to the ##x'## axis. You have it parallel to the ##y'## axis.
PeroK said:
The rod is parallel to the x′ axis. You have it parallel to the y′ axis.
Thanks, I'll edit the post
