Multiple integrals for finding volume
9 replies · 3K views
aruwin
How do I solve this? How do I determine the range? Ill they be triple integrals?Please explain to me.
Find the volumes in R3.
1. Find the volume U that is bounded by the cylinder surface x^2+y^2=1 and the plane
surfaces z=2, x+z=1.
2. Find the volume W that is bounded by the cylindrical surfaces
x^2 + y^2 = 1 and x^2 + z^2 = 1.
I know these are 2 questions and they're both about finding volumes but the second one seems to have 2 cylinders :confused: ??I don't get it.
hi aruwin! :smile:
these integration problems are basically about slicing the volume in a convenient way
for the first one …
… horizontal slices seem sensible:
what is the shape of the horizontal slice at a general height z ?
yes, two cylinders
again, try horizontal slices, write the second condition as x2 = 1 - z2, and remember the RHS is a constant (for that slice) :wink:
tiny-tim said:
hi aruwin! :smile:
for the first one …
yes, two cylinders
Horizontal slice?You mean, like a triangle?? And what do you mean by RHS is a constant?:confused:
won't one side be curved? :confused:
in x2 = 1 - z2, z is constant for any particular slice
LOL,of course one side should be a curve. My bad, I meant horizontal slice as in a slanting plane. Is that what you refer to as horizontal slice?
no, a horizontal slice means between the horizontal planes at heights z and z+dz
tiny-tim said:
hi aruwin! :smile:
for the first one …
yes, two cylinders
Can you show me a diagram for the first cylinder?I am guessing it looks like a cylinder with the one slanting surface but I can't picture the XYZ coordinate inside it. I really need to see a picture.
yes, it is a cylinder with one slanting surface :smile:
but the easiest way of integrating is to divide it into horizontal slices (so each slice is a "damaged" circle with a bit sliced off)
you could integrate by dividing it into slanting slices, but
i] you'd have to define a new parameter x+z, and integrate with respect to that
ii] you'd need to know the formula for the area of an ellipse (ok, i admit that's fairly easy)
iii] you'd still have a problem with "damaged" circles at the bottom!​
1. Find the volume U that is bounded by the cylinder surface x^2+y^2=1 and the plane surfaces z=2, x+z=1.
Before leaping into calculus, think what this shape looks like. What shape might you make with two of them?
tiny-tim said:
two cylinders
I think this one would be much easier using vertical slices in the x-z plane. The slices would be squares.
oooh yes … horizontal slices work, but vertical slices are easier! :smile:
