[MultiVarCalc] Find the volume of the solid
The discussion focuses on calculating the volume of the solid bounded by the cone defined by the equation ##z = \sqrt{x^2 + y^2}## and the paraboloid given by ##z = 12 - x^2 - y^2##. The user initially set up the volume integral using polar coordinates, leading to the expression ##V = \int_0^{2\pi} \int_0^3 \int_r^{r^2} r\, dz\, dr\, d\theta##. However, it was identified that the upper limit for the innermost integral should be corrected to ##12 - r^2##, resulting in a final volume of ##\frac{99}{2} \pi##. This correction is crucial for obtaining the accurate volume of the solid.
  • Understanding of polar coordinates in calculus
  • Familiarity with volume integrals and triple integrals
  • Knowledge of the equations of cones and paraboloids
  • Ability to perform algebraic manipulations and solve equations
  • Study the application of polar coordinates in multiple integrals
  • Learn about the derivation and properties of cones and paraboloids
  • Explore advanced techniques for calculating volumes of solids of revolution
  • Practice solving volume integrals with varying limits of integration
Students studying calculus, particularly those focusing on multivariable calculus and volume calculations, as well as educators looking for examples of solid volume problems involving polar coordinates.
bornofflame
Find the volume of the solid between the cone ##z = \sqrt{x^2 + y^2}## and the paraboloid ##z = 12 - x^2 - y^2##.
##x^2 + y^2 = r^2##
I drew a simple diagram to start off with to visualize the solid formed by the intersection of these equations which is in the attached image along with my work in raw form.
Since we're dealing with circular cross sections the polar coordinates will be best, (read easiest), to work with for me.
Volume = ?
Setting up the integral
##V = \int_R dV = \int_R r\, dz\, dr\, d\theta##
## z = \sqrt{x^2 + y^2} = \sqrt{r^2} = r##
## z = 12 - x^2 - y^2 = 12 - r^2##
lower limit for z ## = r##
upper limit for z ## = 12 - r^2##
##\sqrt{x^2 + y^2} = 12 - x^2 - y^2##
##r = 12 - r^2##
##r^2 + r - 12 = 0##
##(r + 5)(r - 3) = 0##
##r = -4, 3: -4 \text{ is out of bounds, so }r = 3##
## 0 \leq r \leq 3##
##= \int_0^{2\pi} \int_0^3 rz\, \left. \right|_r^{r^2}\, dr\, d\theta##
##= \int_0^{2\pi} \int_0^3 r^3-r^2\,dr\,d\theta##
##=\int_0^{2\pi} \frac 1 4 r^4- \frac 1 3 r^3 \left. \right|_0^3 \,d\theta##
##=\int_0^{2\pi} \frac 81 4 - 9\, d/theta = \frac 81 4 \theta - 9\theta \left. \right|_0^{2\pi}##
##=\frac {81} 4 (2\pi)-9(2\pi) = \frac {81} 2\pi - 18\pi = \frac {81} 2\pi - \frac {36} 2 \pi##
##=\frac {45} 2 \pi##
It looks like the upper limit in the innermost integral, the one over ##z##, is wrong. It needs to be the ##z## vertical coordinate of the paraboloid where the horizontal coords are ##(r,\theta)##. That will not be ##r^2##.
Should the upper limit be ##12 - r^2##?
Which would give me ##\frac {99} 2 \pi## as an answer instead.
Yes
  • · Replies 34 ·
  • · Replies 20 ·
