Multivariable Calculus Chain Rule Problem: Wave equation
The discussion centers on demonstrating that the function z = f(x + at) + g(x - at) satisfies the wave equation. The user encountered difficulties when using partial derivatives instead of the traditional derivative notation, leading to confusion about the presence of cross terms. It was clarified that f(u) and g(v) are functions of a single variable, meaning there should be no cross terms in the second derivatives. The distinction between using f'(u) and ∂z/∂u is emphasized, as the latter implies a multivariable context. Ultimately, the user realized their mistake in treating f and g as functions of both u and v instead of separately.
Agent 47
Show that any function of the form
##z = f(x + at) + g(x - at)##
is a solution to the wave equation
##\frac {\partial^2 z} {\partial t^2} = a^2 \frac {\partial^2 z} {\partial x^2}##
[Hint: Let u = x + at, v = x - at]
2. The attempt at a solution
My problem with this is not that I haven't been able to solve it. The book's solution is right here:
I began to have trouble when I decided not to use f'(u) and g'(v) instead I used ##\frac {\partial z} {\partial u}## and ##\frac {\partial z} {\partial v}##
When I did this I got
##\frac {\partial^2 z} {\partial x^2} = \frac {\partial^2 z} {\partial u^2} + \frac {2 \partial^2 z } {\partial u \partial v} + \frac {\partial^2 z} {\partial v^2}##
and
##\frac {\partial^2 z} {\partial t^2} = a^2 (\frac {\partial^2 z} {\partial u^2} - \frac {2 \partial^2 z } {\partial u \partial v} + \frac {\partial^2 z} {\partial v^2})##
And that does not fulfill the condition stated in the beginning.
So I have a two questions in the end:
1)What is the difference between writing f'(u) and ##\frac {\partial z} {\partial u}##?
2)Do ##\frac {2 \partial^2 z } {\partial u \partial v}## and ##- \frac {2 \partial^2 z } {\partial u \partial v}## both evaluate to 0? (That's the only way ##\frac {\partial^2 z} {\partial t^2} = a^2 \frac {\partial^2 z} {\partial x^2}##) or did I do something wrong in my calculations?
One ordinarily would use the notation f'(u) when f is deemed to be a function of a single variable, and ∂f/∂u when f is a function of several variables including u. However, the notation shouldn't make any difference.
Your problem is that when you went for ∂##^2##z/∂x##^2## you regarded ∂f/∂u as a function of both u and v, which it is not -- it is a function of u alone. Same with v. So you are not going to get any cross terms.
This may be a good reason why ∂f/∂u isn't a good way to notate f'(u).
Thank you so much. This has been bothering me for a while. So basically I interpreted this as ##f(u,v)## instead of ##f(u)## and ##g(v)## separately. Right?
Exactly right.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
