Multivariable calculus equation of a plane
5 replies · 2K views
iScience
equation of the form
ax+bx+cx=a0+b0+c0
ax+bx+cx=d
what exactly does "d" represent? is it the distance of a point from the plane? or is it the shifting of the plane along the normal vector of the plane?
and how does "d" represent that again?
A way to write an equation for a plane in [itex]\mathbb{R}^3[/itex] is
[tex]\vec{w} \cdot \vec{r} = d[/tex]and the plane contains the point [tex]d\frac{ \vec{w}}{\left\|\vec{w}\right\|^2}[/tex] You can check that the above is true. Now if [itex]\vec{u}[/itex] and [itex]\vec{v}[/itex] are parallel to the plane and one is not a scalar multiple of the other, then we could write the plane as [tex]\vec{r}(s,t) = d\frac{ \vec{w}}{\left\|\vec{w}\right\|^2} + s\vec{u} + t\vec{v}[/tex] since we can always parameterize the plane as a point on the plane plus scalar multiples of two spanning vectors added on.
So you could think that the plane has been shifted by [itex]d\frac{ \vec{w}}{\left\|\vec{w}\right\|^2}[/itex], which is along the normal. It is somewhat ambiguous perhaps because some other shifts in other directions would result in the same plane.
The above applies to planes in [itex]\mathbb{R}^3[/itex].
ax+bx+cx=a0+b0+c0
ax+bx+cx=d
I guess you mean ##ax + by + cz = d##, not what you wrote. In that case the quantity$$\frac{|d|}{\sqrt{a^2+b^2+c^2}}$$gives the distance of the plane from the origin.
Also, if x= y= 0 then cz= d so z= d/c, if x= z= 0 then by= d so y= d/b, and if y= z= 0 then ax= d so x= d/a. That is, (d/a, 0, 0), (0, d/b, 0), and (0, 0, d/c) are the x, y, and z intercepts of the plane.
yes that's what i meant, could you show me how this yields the distance of the plane from the origin?
what does d itself represent?
Look in your calculus book how to calculate the distance from a plane to a point and use it to calculate the distance to (0,0,0).
##d## by itself doesn't have any particular meaning. If you multiply the equation through by ##2## you will have the same plane but now ##2d## on the right side. So ##d## in relation to the coefficients is what is significant. And the formula above gives geometric meaning to it.
