Multivariable chain rule proof
The discussion revolves around proving a relationship involving a function of two variables, specifically using the multivariable chain rule. The original poster presents a problem where a function f(x, y) satisfies a scaling property with respect to a constant p and a variable λ, leading to a specific equation involving partial derivatives.
  • Participants discuss how to apply the multivariable chain rule to differentiate both sides of the given equation with respect to λ. There are questions about the setup of variables and the implications of choosing λ=1 for the proof.
Some participants have suggested specific steps to differentiate the equation, while others are clarifying the reasoning behind variable substitutions and the choice of λ. There is an ongoing exploration of how to handle both sides of the equation after differentiation.
Participants note that the function has continuous first order partial derivatives and that the proof must hold for all real numbers λ, raising questions about the implications of evaluating at λ=1.
mrcheeses
Take a constant p ≥ 1 and f(x, y) a function of two variables with continuous
first order partial derivatives. If, f(λx, λy) = (γ^p)f(x,y) for λ ε ℝ, prove that
x(∂f/∂x) + y(∂f/∂y) = pf
f(λx, λy) = (λ^p)f(x,y)
I just don't know how to start. I know you have to use multivariable chain rule. Can someone point me in the right direction?
Take the derivative of both sides of your defining relation with respect to λ. Then put λ=1.
how would you differentiate with respect to lambda?
Also made a mistake.
Its: f(λx, λy) = (λ^p)f(x,y)
Put x'=λx and y'=λy, so f(λx, λy)=f(x',y'). Apply the multivariable chain rule to find ∂f(x',y')/∂λ. Then differentiate the other side with respect to λ as well.
why do you put x prime=λx and y prime=λy?
Just apply the multivariable chain rule to ∂f(x',y')/∂λ. You'll see.
What about the right side? Is p * lamdba^(p-1) f(x,y) correct?
Yes, now do the left side, that's the chain rule part. Remember in the end you are going to put λ=1.
But lamda is an element of all real numbers right? So how can you prove this if we only choose lambda as 1?
I got ∂f/∂x'*x + ∂f/∂y' *y on the left side. What do we do after that?
You can get a more complicated relation that's true for general λ. But the specific result they want you to prove doesn't have a λ in it. That's why I suggest putting λ=1 after you do the differentiations.
Convince yourself that e.g. ∂f(x',y')/∂x'=∂f(x,y)/∂x=∂f/∂x when λ=1.
Got it, thanks!
  • · Replies 21 ·
