What am I doing wrong in calculating the capacitance of an air-filled capacitor?
  • Thread starter Thread starter AdKo
The discussion centers on calculating the capacitance of an air-filled capacitor with parallel plates, each measuring 7.60 cm² and separated by 1.8 mm, under a 20 V potential difference. The formula used is C = ε₀(A/d), where ε₀ is the permittivity of free space (8.85 x 10^-12 F/m). The initial calculation yielded a capacitance of 3.74 x 10^-10 F, which was incorrect due to improper unit conversion from cm² to m². The correct conversion shows that 7.60 cm² equals 0.000760 m², leading to a final capacitance of 3.74 x 10^-12 F.
  • Understanding of capacitance and the formula C = ε₀(A/d)
  • Knowledge of unit conversions, specifically from cm² to m²
  • Familiarity with the concept of parallel plate capacitors
  • Basic algebra for manipulating equations
  • Study the derivation and applications of the capacitance formula C = ε₀(A/d)
  • Learn about the effects of dielectric materials on capacitance
  • Explore practical applications of capacitors in electronic circuits
  • Investigate advanced topics in electrostatics and electric fields
Students in physics or electrical engineering, educators teaching capacitance concepts, and anyone involved in electronics design or analysis.
AdKo
My answer is off by 10^-2!
An air-filled capacitor consists of two parallel plates, each with an area of 7.60cm^2 and separated by a distance of 1.8mm. If a 20 V potential difference is applied to these plates, calculate the capacitance.
C=\epsilon_{0}\frac{A}{d}
=(8.85*10^-12)\frac{0.076m^2}{0.0018m}
=3.74*10^-10F
Book answer: 3.74*10^-12? What am I doing wrong? thanks.
Check your conversion from cm2 to m2.
I don't get it. Do you need to count the ^2 too? How do you convert that?
I know that 7.6cm=.076m..
You know that there are 100 cm in a metre, so in a metre-squared, there are 1002=10 000cm.
But isn't cm square also? Or is it like (xm)^2 and you need to distribute so x^2m^2? Cm^2 already has the magnitude distributed right? Is that the reason?
By the way, I've always ignored all of the powers that came after the units.. But I guess that's because I never converted them. I really need this explained =/
Wait is it like this?:
\frac{5cm^2}{1}*\frac{1m}{(100cm)^2}
=\frac{5cm^2}{1}*\frac{1m}{10000cm^2}
?? -- I guess that would mean the 5cm^2 already had its square root distibuted? Am I thinking the right way?
I don't really know what you mean here. The unit is centimetre squared, and we are trying to convert it to metres squared (we can do this, since they are both units of area)
OK, well if you were measuring the length of something, then a valid answer would be, say, 10cm, since the centimetre is a unit of length. We can convert this to metres by dividing by 100, since the metre is a unit of length also.
Now, suppose we have a measurement in centimetres squared. Now, this is a unit of area: as an example, if we draw a square on paper with sides 5cm, then the total area will be 5x5=25cm2.
So, to convert from centimetres squared to metres squared, consider drawing a square of sides 1m on paper. Since 1m=100cm, we know that each side is 100cm long. But, what is the total area in centimetres squared? Well, area=lengthxheight, and so for a square of sides 100cm, it is area 10 000cm2.
So, we see that a square of area 1m2 has area 10 000cm2 i.e. 1m2=10 000cm2.
Now, to convert from centimetres squared to metres squared, consider drawing a square of sides 1m on paper. Since 1m=100cm, we know that each side is 100cm long. But, what is the total area in centimetres squared? Well, area=lengthxheight, and so for a square of sides 100cm, it is area 10 000cm2.
I think I totally understand now! Your explanation was great. So would this be correct??
(l_ is the base + height)
l_ :1mx1m=1m^2
l_ :100cmx100xcm=10000cm^2
(l_ is the base x[/color] height)
l_ :1mx1m=1m^2
With the slight correction, that base x height is the area, then yes, you are correct.
Alright, thanks a lot!
  • · Replies 16 ·
