My made solenoid doesnt induce magnetic field. What did I miss?
The discussion revolves around a school project involving a solenoid that failed to induce a magnetic field. The user initially used a thin brown wire, which turned out to be insulated, preventing current flow. After switching to ordinary insulated copper wire, the LED lit up, indicating that the original wire was not conducting electricity. Participants suggested scraping off the insulation from the wire ends to ensure proper electrical connections. Ultimately, the user successfully resolved the issue by removing the insulation, allowing the solenoid to function correctly.
akamine
Hey, I have a school project and I need a solenoid to induce a magnetic field.
http://www.yourpicbox.com/images/orhBIhKZq6426.jpg
I made a solenoid by winding a wire (I'm not sure what to call this wire. It's thin and brown.) to a pen case. I made 3 layers, 100-200 turns each.
When I tested it, connecting it to 6V DC, nothing happened. No magnet.
So I experimented other thing :
I connect a LED and 1.5V DC with this wire. LED didnt glow.
Then I change this wire with ordinary insulated copper wire. The LED glow brightly.
It seems that this wire doesn't conduct any current. What did I miss here?
A solenoid like that can quickly drain power from the battery. Try another battery, or another power supply. Also, did you scrape the insulation on the wire when connecting to the battery?
Yes it sounds like you just haven't made proper connection to the ends of the wire. It often can be quite tricky to make a good electrical connection to enamelled wire. I recommend that you try the following procedure :
1. Burn off the insulation near the ends with a cigarette lighter.
2. Scrap away the burnt enamel with steel wool until you see shiny copper visible.
3. Solder short pieces of regular insulated copper wire (preferably "tinned" though it's not essential) to the ends where you're cleaned off the enamel. You'll find that this regular type wire is much easier to work with and make connection to your battery or other circuitry. Also, if you get the solder to stick well then you know the enamel is properly removed and the connections will be good.
As an alternative, it's also easy to scrape the insulation with sand paper.
thanks
I did not know the wire is insulated.
It works just fine after I scrap it :)
many thanks
akamine said:
thanks
Think about it, if that wire wasn't insulated then all the turns would be touching each other and all you'd end up with is a big short circuit. :)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
