- #1
sqljunkey
- 181
- 8
I created this in java just a while ago.
Thanks!sophiecentaur said:It's great when someone has taken the trouble to do something like this. Something that we all talk about but never actually get round to doing.
I didn't use wave equations. You can look for yourself I uploaded the code : https://github.com/sqljunkey/sim.particle all the action happens in Engine.java .sophiecentaur said:I assume you take the standard interference pattern equation and use that to calculate the probabilities (?).
sqljunkey said:You can look for yourself I uploaded the code :
As I read the code, you are sending small solid balls towards the screen and when they collide with the edge of a slit you are adding a fixed transverse amount to their momentum. This isn't simulating the double slit in either classical or quantum mechanical form.sqljunkey said:You can look for yourself I uploaded the code : https://github.com/sqljunkey/sim.particle all the action happens in Engine.java .
Not only negative values but a continuum of phase.Nugatory said:I don't think there's any way of getting a plausible simulation without using some of the mathematics of wave propagation - interference requires the possibility of negative amplitudes
It's a nice looking animation (and pretty convincing as a one off demonstration) but not based on any accurate physics at all, I'm afraid. Neither the physics of waves nor the likely behaviour of objects around black holes.sqljunkey said:I coded this thinking how something like a black hole with the mass of the moon traveling at high velocity to the sun would get caught in it's orbit for a brief time and then escape. Since the moons would be of the same size all the time the orbit escape angles would be nearly the same for a range of "orbit entering positions". That is not what actually happens with particles probably, but that is(I think) what creates the effect you see.
Nugatory said:As I read the code, you are sending small solid balls towards the screen and when they collide with the edge of a slit you are adding a fixed transverse amount to their momentum. This isn't simulating the double slit in either classical or quantum mechanical form.
sqljunkey said:I could change the momentum to be proportional to the distance and it would probably be the same thing. Probably even better. and I'm not simulating waves and wave interference.
Your thread title suggests something fairly different from that.sqljunkey said:I could change the momentum to be proportional to the distance and it would probably be the same thing. Probably even better. and I'm not simulating waves and wave interference.
That is correct, although someone reading the thread title might be forgiven for thinking that you were trying to.sqljunkey said:I'm not simulating waves and wave interference.
The purpose of a particle simulation of the Double Slit experiment is to understand the behavior of particles, such as electrons or photons, when they are passed through two narrow slits. This experiment helps to demonstrate the wave-particle duality of matter and the concept of interference.
The simulation works by using algorithms and mathematical models to simulate the behavior of particles as they pass through the double slits. It takes into account factors such as the size of the slits, the distance between them, and the speed of the particles to create a realistic representation of the experiment.
Yes, the simulation can accurately represent the results of the actual Double Slit experiment. However, it should be noted that the simulation is based on mathematical models and may not perfectly replicate the exact results of a physical experiment due to factors such as measurement error and external influences.
A particle simulation of the Double Slit experiment can help us understand the fundamental principles of quantum mechanics, such as wave-particle duality and the concept of interference. It can also provide insights into the behavior of particles at a microscopic level and how they interact with their environment.
While particle simulations can provide valuable insights, they do have limitations. They are based on mathematical models and may not perfectly replicate the results of a physical experiment. Additionally, the simulation may not be able to account for all external factors that can influence the behavior of particles in the experiment.
