Natural units and electron mass
4 replies · 5K views
spaghetti3451
I am trying to express some physical constants in natural units of ##c=1## and ##\hbar=1##.
Let's start with the electron mass. In SI units, the electron mass is ##0.511 \text{MeV}/c^{2}##. I understand that in natural units, the electron mass is simply ##0.511\ \text{MeV}##. Now, is the electron mass given by ##\frac{\hbar c}{0.511 \text{MeV}} = 1.01 \times 10^{-21}\ \text{cm}##?
Notice that expressing mass in MeV alreafy has c=1 factored in - so why would the conversion factor have an explicit c in it?
How often do you normally convert units by dividing by the quantity you are converting?
When you convert quantity x from unit a into unit b, wouldn't you just multiply it by a conversion factor?
Observations:
To convert MeV into natural units of length, you need to know how many natural length units there are in 1MeV.
In general - setting ##\hbar = c = 1## still leaves some arbitrary units.
A "centimeter" is not usually a natural unit.
See, for example, plank units.
https://en.wikipedia.org/wiki/Natural_units#Planck_units
It looks like the calculation you did just normalizes the electron rest mass and tells you how big the unit of length is, in terms of other systems of units, for the particular set of natural units chosen.
The mass expressed in ##\text{MeV}## needs to be converted to ##\text{cm}^{-1}##. Now, ##\frac{\text{MeV}}{\hbar c}## has dimensions of length. Therefore, ##\frac{1 \text{MeV}}{\hbar c}## gives the conversion factor from ##\text{MeV}## to ##\text{cm}^{-1}## in SI units.
There is a typo in my calculation. It is actually ##\frac{0.511 \text{MeV}}{\hbar c} = 2.58 \times 10^{12} \text{cm}^{-1}##.
It does, but this system of units is heavily used in particle physics and cosmology.
What do you think?
You seem to be thinking of plank units ... to deal with mass-energy you usually need to also normalize the gravitational constant.
Other schemes normalize the mass of the electron or some other particle commonly dealt with... which amounts to picking a different value for G.
If m is the electron mass, then ##(mc^2)/\hbar c## gives dimensions of [E]/[E.L] = L^-1 ... so that comes out right for you... just makes sure you express ##\hbar c## in units of MeV.cm
