SlurrerOfSpeech
- 141
- 11
Is that "normal" for a machine running Windows 10? I have a 120GB hard drive and 55.2GB is being used for System & Reserved. Seems high.
The discussion centers on the high usage of System & Reserved space on a Windows 10 machine with a 120GB hard drive, where 55.2GB is allocated. Users suggest that this may be due to an upgrade from previous Windows versions, leading to leftover files. Recommendations include using WinDirStat for visualizing disk usage, performing Windows Disk Cleanup, and considering a larger drive if space remains insufficient. The consensus indicates that 120GB is inadequate for modern usage, especially with Windows 10's storage requirements.
PREREQUISITESThis discussion is beneficial for Windows 10 users, IT professionals, and anyone experiencing storage issues on their systems, particularly those with limited hard drive capacity.
Several times in the past I found myself short of storage space. Before investing in a bigger disc, I set out to delete unneeded files. Once, I converted all my pictures to lower resolution.UsableThought said:I agree with @Mark44 that 120G is pretty small these days. Still, what I read about Windows 10 suggests that it ought to install in far less space than previous Windows versions, and much less than 52G; which means that somehow you may have accumulated unnecessary bloat. I do remember that older versions of Windows would acquire crud quite quickly, e.g. packages required for updates would be kept on even though no longer needed. I'd suggest two things:
1) If you haven't already, get yourself one of the various apps that shows disk storage graphically via clusters of folders & file types, so that you can look inside your System folder, for example, and quickly zero in on the files or groups of files that seem to be hogging up space; you can Google on the various folder & file names to learn what they do & whether they need to be kept. That's how I always did it when I was still running Windows, up until last year. As for what app to use, Windows 10 apparently has an improved feature for managing disk space, but I've always preferred third-party apps for this purpose. The freeware WinDirStat still seems to be getting recommendations even though it doesn't say that it's been updated for 10: https://windirstat.net
2) Assuming you find and remove any unneeded files, with only 120G you may find you want still more room; in which case you can look for articles with tips on shrinking Windows, e.g. by turning off hibernation, etc. - see for example https://www.laptopmag.com/articles/reclaim-disk-space-windows-10
anorlunda said:In every case I regretted my efforts to conserve space and I lost stuff that I would like to have.
the connection is simply that you talked about deleting unneeded files. That's what I did and regretted.UsableThought said:I don't know why you're quoting my post as part of your comment, given that there is zero connection between what you did & what I am suggesting to the OP. In terms of being helpful, maybe you could explain how you went about getting more storage?
anorlunda said:the connection is simply that you talked about deleting unneeded files. That's what I did and regretted.
I would say this is not unusual, especially for a system using an OEM install. I suggest you perform the following in order:SlurrerOfSpeech said:Is that "normal" for a machine running Windows 10? I have a 120GB hard drive and 55.2GB is being used for System & Reserved. Seems high.
