Need answers on tubular structures
  • Thread starter buf006
    Structures
9 replies · 3K views · last reply
buf006
Ok so I have been looking over the internet on reading material on structures of tube. From experience I know this happens with items like straws (see illustration below). Is there an actual name of the phenomenon that happens (maybe a few formulas)
Three-panel diagram of a tube under axial compression: arrows push both ends inward, the tube bows in the middle, then a crack appears at the bulge until it breaks.
If you don't understand the picture from just the drawings feel free to ask and i will try to clarify as much as I can.
thanks for the move. i really didn't know where to ask this question.
before the buckle. i want to know what it is called when it starts to bend and before it buckles.
I agree that ank_gl has given the correct answer to post 1. Regarding your question in post 4,
when the tube starts to bend but before it buckles, this is called bending deflection.
O ya. i know its buckling when the tubes buckles (haha). With bending deflection isn't that only when a force is applied perpendicularly to the tube and not when applied against the tube?
I would suggest you to read a chapter about buckling from some good book, or simply http://en.wikipedia.org/wiki/Buckling
Just for a start, compressive failure is way more complex than tensile failure.
buf006 said:
With bending deflection, isn't that only when a force is applied perpendicularly to the tube?
No, bending deflection occurs when bending moment is applied to the tube, regardless of which
force caused the bending moment.
& the bending moment can occur due to load eccentricity, material inhomogeneity etc. Compressive failure study is more experimental than theoretical.
